RS4 B7 REVERSE CAMERA
Stu3y
Post by Stu3y » Sat Mar 25, 2023 9:30 pm
Hi Guys,
I am now a new owner of my first RS4 B7.
I am looking to fit a reverse camera to it, using a kit which replaces the boot handle unit.
I have fitted reverse cams before to Vag cars however, I have spent hours searching the Internet and various forums for instructions on this particular car but have come up blank
Just wanting to know if anyone has a guide or has done one of the cheap cameras on thier own B7.
Thanks in advance
Stuart
Sent from my SM-G781B using Tapatalk
JamesBaby
Re: RS4 B7 REVERSE CAMERA
Post by JamesBaby » Sat Mar 25, 2023 11:17 pm
See my thread in Readers Rides. I fitted a reverse camera. Did a write up on that and the head unit.
dan32v
Post by dan32v » Sun Mar 26, 2023 9:23 am
Dijon en FRANCE
Stu3y
Post by Stu3y » Mon Mar 27, 2023 11:32 am
Apologies in advance to everyone. I am not great with electrics and new to the car also.
I can normally get things done easily enough once I have the instructions.
So I was expecting that this would be video cable run through the car to the head unit and then source power to the camera and trigger wire.
Either from headunit wires or reverse light wires.
Unless they are hidden I can't find any Video cables from the head unit.
Stu3y
Post by Stu3y » Mon Mar 27, 2023 12:24 pm
Thankfully the owner gave me the original Bix to the head unit. Just dug it out and found this.ImageImage
Stu3y
Post by Stu3y » Sat Apr 08, 2023 9:29 pm
Got the camera in now. Used an ebay camera but actually quite pleased.
Looks pretty oem, just need to adjust the colour on head unit. And set up my lines.
Not bad for £54.ImageImageImage
Stu3y
Post by Stu3y » Sat Apr 08, 2023 9:47 pm
I have a pioneer avh-z9200 DAB.
Anyone know if its possible to get it to display the lines for larking sensors.
It has the logo as part of the camera image but doesn't do anything.
Would be nice to know which sensor gas something closest to it.
JamesBaby
Post by JamesBaby » Sun Apr 09, 2023 11:53 am
Lines are a function of the camera usually. Normally IIRC there is a wire you cut to disable the lines. Check your camera instructions.
Stu3y
Post by Stu3y » Sun Apr 09, 2023 6:04 pm
Mine has a little white loop wire, but not sure if that is to reverse the image to use as a front camera. My head unit has lines anyway, that I can turn on and off and adjust to suit the car/camera.
Users browsing this forum: No registered users and 70 guests
