Steering Issue/Fault
mikec1979
Post by mikec1979 » Wed Mar 22, 2023 4:09 pm
Hi all,
Hoping someone may be able to help. I have a yellow power steering light on, was intermittent, now it wont clear. Had it scanned:
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000695588 Dataset Number: 4G0909852L 0037
Coding: 101001010001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: BA3845153D6F52434D-80EE
1 Fault Found:
15888 - Terminal 15
U1405 00 [008] - Implausible signal
[Unplausibles Klemme 15 (Z¸ndungssignal)]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 153
Reset counter: 195
Mileage: 71116 km
Date: 2023.03.16
Time: 08:50:14
Write only channel
Obviously I am dreading a potential £4k bill for a new rack....
Has anyone come across this before?
Thanks in advance
super7
Re: Steering Issue/Fault
Post by super7 » Sat Apr 01, 2023 6:38 am
Not sure if this helps much but I had this intermittently come on and off for about 3 months and it just went away.
It is a covered apart as part of the Audi extended warranty. Which is £1,500 a year. You can buy it online and the car isn’t checked. Just a 30 day hold on no claims. So if you can make it thru 30 days, may be cheaper to get the warranty?
