Hi Guys in need of some help. Had my 2017 Audi RS6 performance over a year been flawless no issues.
Recently had an issue pop up I have some fault codes attached if any of you guys can help.
Everything seems to be linked to one problem just not sure what is it right now.
Thanks in advance.
Details Below
10,February,2023,17:48:56:22147
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WUAZZZ4G5HN904663 License Plate:
Mileage: 35579km-22107mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 1B 22 28 36 3B 3C
42 44 46 52 53 55 5F 62 65 6C 6D 72 82 84 85 8B 8E 8F 90 BA
47
VIN: WUAZZZ4G5HN904663 Mileage: 35579km-22107miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Cannot be reached 0100
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
84-Night Vision -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CWUC) Labels: Redir Fail!
Part No SW: 4G0 906 560 F HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0003
Revision: NCH63--- CVN: 148E177A
Coding: 122A00326546090B3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906560F 001004
ROD: EV_ECM40TFS0114G0906560F.rod
VCID: 2B0304AEB38058636E0-807E
VINID: 9E546AAAA1171587890041860C6108165E
29 Faults Found:
7039 - Thermostat for Mapped Engine Cooling (F265)
P0598 00 [175] - Short to Plus
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 37 °C
Intake air temperature: 32 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.591 V
Unlearning counter according OBD: 40
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
18062 - Coolant Pump 2
P261A 00 [035] - Open circuit
Not Confirmed - Tested Since Memory Clear
12352 - Coolant Pump for Intercooler
P023A 00 [035] - Open Circuit
10385 - Coolant Valve for Cylinder Head
P199D 00 [035] - Short to GND
9490 - Oil Pressure Regulation Valve
P165F 00 [035] - Short to GND
18610 - Solenoid Valve for Piston Oil Cooling
P25AA 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
14195 - Cam Actuator B Cylinder 5
P31A5 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
14204 - Cam Actuator B Cylinder 8
P31A8 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
14189 - Cam Actuator B Cylinder 3
P31A3 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
14186 - Cam Actuator B Cylinder 2
P31A2 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
14243 - Exhaust Cam Actuator B Cylinder 5
P31AD 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
14252 - Exhaust Cam Actuator B Cylinder 8
P31B0 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
14237 - Exhaust Cam Actuator B Cylinder 3
P31AB 00 [035] - Short to GND
14234 - Exhaust Cam Actuator B Cylinder 2
P31AA 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
14219 - Cam Actuator A Cylinder 5
P31B5 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
14228 - Cam Actuator A Cylinder 8
P31B8 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
14213 - Cam Actuator A Cylinder 3
P31B3 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
14210 - Cam Actuator A Cylinder 2
P31B2 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Voltage terminal 30: 11.567 V
14267 - Exhaust Cam Actuator A Cylinder 5
P31BD 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
14276 - Exhaust Cam Actuator A Cylinder 8
P31C0 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
14261 - Exhaust Cam Actuator A Cylinder 3
P31BB 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
14258 - Exhaust Cam Actuator A Cylinder 2
P31BA 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
2972 - Intake Manifold Flap; Bank 1
P2009 00 [175] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:39:41
Engine RPM: 184.50 /min
Normed load value: 28.2 %
Voltage terminal 30: 10.130 V
Engine status: COENG_CRANKING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 2
7651 - Secondary Air Pump Relay (J299)
P1435 00 [175] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:39:41
9014 - Secondary Air Injection System Valve 2 (N320)
P0417 00 [035] - Shorted
7660 - Secondary Air Injection Solenoid Valve (N112)
P1421 00 [175] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:39:41
4235 - Evap System Purge Control Valve (N80)
P0458 00 [035] - Short to Ground
10620 - Turbocharger Bypass Valve 2
P00C1 00 [035] - Short to GND
4269 - Turbocharger Bypass Valve Control Circuit
P0034 00 [035] - Low
Readiness: 0010 1001
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 BH HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H22 1010
Revision: --H22--- CVN: DCB4FFF1
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 75B7E2D625445E93C84-8020
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
Component: ESP9 Premium H01 0100
Revision: -------- Serial number: --------------
Coding: 64BF994926FD99929F00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 42DD490A240AB92BBD6-8016
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0825
Revision: 00002001
Coding: 05B96F0E000000000000
VCID: 005983026A066B3BEB2-8054
Address 06: Seat Mem. Pass
Cannot be reached
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 BM HW: 4G0 820 043 BM
Component: KLIMA 4 ZONEN H14 0113
Serial number: 15031700041610
Coding: 682270BA150000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 6B83C4AE730098632E0-803E
4 Faults Found:
0210 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 15
Mileage: 35162 km
Date: 2022.11.03
Time: 20:48:30
Voltage terminal 30: 14.45 V
Outside temperature: 7.5 °C
Engine RPM: 1841 /min
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 27
Mileage: 34810 km
Date: 2022.10.20
Time: 19:35:31
Voltage terminal 30: 13.13 V
Outside temperature: 14.0 °C
Engine RPM: 1500 /min
0387 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 27
Mileage: 34810 km
Date: 2022.10.20
Time: 19:35:30
Voltage terminal 30: 13.18 V
Engine RPM: 1501 /min
0560 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 16
Mileage: 33724 km
Date: 2022.09.13
Time: 19:16:19
Voltage terminal 30: 14.07 V
Outside temperature: 17.5 °C
Inside temperature: 29.01 °C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0368
Revision: 1402003S Serial number: 00001620291301
Coding: 0105000040309FF2F90140C4A0001800CF9DC7082F08020180000894E101130200400009090000
VCID: 73B3DCCE2BB040A3E60-8026
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 170128 H38 0080
Serial number: 170215010701
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20162503X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BH HW: 4G0 941 531 BH
Component: E1 - LDS H07 0044
Serial number: 06 03 2017 00000670
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA126752000030050185
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 7109889800PAG0MUFU03
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 27
Mileage: 31961 km
Time Indication: 0
Date: 2022.07.17
Time: 12:09:55
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0080
Revision: -------- Serial number: 56231708310099
Coding: B83B27
ASAM Dataset: EV_EPHVA2CAU64X0000 001014
ROD: EV_EPHVA2CAU64X0000.rod
VCID: 363525DA78C2158B01E-8062
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0055
Serial number: 00000000000000
Coding: 7E02010102
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 290FFEA6B97C4A739CC-807C
1 Fault Found:
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_LRRS_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 97
Mileage: 33003 km
Date: 2022.08.20
Time: 19:46:34
Control Module temperature: 27 °C
Voltage terminal 15: 14.298 V
Velocity_vehicle_reference: 34.97 m/s
Longitudinal_acceleration_vehicle_reference: 0.11 m/s²
Address 14: Susp. Elect. Labels: None
Part No SW: 4G0 907 376 HW: 4G0 907 376 A
Component: J250 DRC FahrwerH02 0040
Revision: 00000000 Serial number: 00894020696000
Coding: 0000000
VCID: 6B83C4AE7F8098632E0-803E
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100D65Z2
Coding: 30333130313730323930554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3B2334EE43E0C8E3FE0-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405V468HI51DF
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB4065468HI29I1
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB400259EU4KH26
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB400E59EU4B25+
Crash sensor for front airbag: driver side:
Serial number: 3554VRB4004597JQBI3K
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400A59OCQOPMX
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372QCF000AV
Coding: 0000FD
VCID: 372B28DE7F48EC831A8-8062
Subsystem 1 - Part No SW: 4G0 951 528 J HW: 4G0 951 528 J
Component: E221 - MFL H08 0010
Serial number: 13 02 2017 E0026697
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G0 920 931 R HW: 4G0 920 931 R
Component: TBenRdwAccNv H15 0225
Revision: 15001308 Serial number: 658180317596035
Coding: 338F910BAFD10600010400
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 353722D665C41E93084-8060
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002563246
Coding: C0ED07481C
GVL: FFADECCCDCAB6C0D41840000
ASAM Dataset: EV_GatewPkoUDS 002000
ROD: EV_GatewPkoUDS_002_AU57.rod
VCID: 3D273AF65DF4C6D3C04-8068
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 4699713304
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 170113000000000008ED
2 Faults Found:
5707 - Tire Pressure Monitoring Module
U0127 00 [008] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 27
Mileage: 35579 km
Date: 2023.01.16
Time: 18:29:56
Voltage terminal 30: 11.5 V
Voltage terminal 15: 0.0 V
Control Module temperature: 2 °C
System status: Awake_Timer_active
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
5735 - Seat/Mirror Postion Control Passenger - Driver
U0209 00 [009] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:34
Voltage terminal 30: 11.9 V
Voltage terminal 15: 11.8 V
Control Module temperature: 32 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 010100
VCID: 3A2D31EA4C5AF1EBE56-806E
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 001503170001011
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 2809FBA2A276737B832-807C
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 23031700040343
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3E253DFA50F2DDCBD9E-806A
7 Faults Found:
0025 - Motor for Rear Left Upper Body Vent
B10D3 22 [008] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 17
Mileage: 35429 km
Date: 2022.11.17
Time: 20:11:16
Voltage terminal 30: 13.36 V
Outside temperature: 9.0 °C
Left Rear Upper Body Vent Motor-Act.val.: 11722
Left Rear Upper Body Vent Motor-Target value: 11722
Left Rear Upper Body Vent Motor-Stop open: 11421
Left Rear Upper Body Vent Motor-Stop closed: 10000
Left Rear Upper Body Vent Motor-Last active operating mode: 5
Left Rear Upper Body Vent Motor-Active operating mode before last: 6
0026 - Motor for Rear Left Upper Body Vent
B10D3 21 [008] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 21
Mileage: 34962 km
Date: 2022.10.24
Time: 21:44:12
Voltage terminal 30: 14.50 V
Outside temperature: 13.5 °C
Left Rear Upper Body Vent Motor-Act.val.: 9699
Left Rear Upper Body Vent Motor-Target value: 9699
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [008] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 17
Mileage: 33735 km
Date: 2022.09.13
Time: 19:56:48
Voltage terminal 30: 13.27 V
Outside temperature: 16.0 °C
Right Rear Upper Body Vent Motor-Act.val.: 11736
Right Rear Upper Body Vent Motor-Target value: 11736
Right Rear Upper Body Vent Motor-Stop open: 11435
Right Rear Upper Body Vent Motor-Stop closed: 10000
Right Rear Upper Body Vent Motor-Last active operating mode: 5
Right Rear Upper Body Vent Motor-Active operating mode before last: 4
0034 - Motor for Rear Right Upper Body Vent
B10D4 21 [008] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 20
Mileage: 34723 km
Date: 2022.10.18
Time: 18:20:20
Voltage terminal 30: 14.54 V
Right Rear Upper Body Vent Motor-Act.val.: 9699
Right Rear Upper Body Vent Motor-Target value: 9699
Right Rear Upper Body Vent Motor-Active operating mode before last: 6
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 17
Mileage: 35422 km
Date: 2022.11.17
Time: 20:05:04
Left rear vent temperature: 14.6 °C
0116 - Temperature Sensor for Rear Right Seat
B1114 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:35
0124 - Rear Right Seat Heater
B1118 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Reset counter: 242
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:35
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000089130114
Coding: 0078130000006001000001010101102030303232203232
VCID: 77ABE8DE3FC82C83DA8-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02PF3H
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372B28DE7FC8EC831A8-8062
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H08 0070
Serial number: 0435782045
Coding: 040312
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_AU21.rod
VCID: 392F2EE649DCFAF3ECC-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H08 0070
Serial number: 0434985985
Coding: 040312
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F1E015E01628202080013
VCID: 45D7521635A48E13984-8010
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000627527
Coding: 011101010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D31EA4CDAF1EBE56-806E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0435601425
Coding: 013A0E20A0B93081C33009840C0112470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00031386811
Coding: 010000
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0511
Coding: 011F1E015E01628202080002
VCID: 44D14F123E9EB71B8FA-8010
1 Fault Found:
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Reset counter: 242
Mileage: 31931 km
Time Indication: 0
Date: 2022.07.16
Time: 17:43:34
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002145583
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 323D19CA94AA09AB2D6-8066
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FE0A202A180200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 34311FD26EBE079B3FA-8060
Left LED Headlamp Power Output Stage 1:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01F00
Right LED Headlamp Power Output Stage 1:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01F00
Power module 1 for left matrix headlamp:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Power module 1 for right matrix headlamp:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 4G1 035 034 D HW: 4G1 035 034 C
Component: MU-H-LN-JP 053 0910
Serial number: K5F AW7PD0J4D5
Coding: 017562010000000013110002001200102F0008E6F17001007E
ASAM Dataset: EV_MUHig6C3Gen2AW7 001290
ROD: EV_MUHig6C3Gen2AW7_AU57.rod
VCID: 1F1BE07EF738B4C3F28-804A
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 TM HW: -----------
Component: ECE 2021/2022 --- 0192
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY807FQ6
Multimedia system control head:
Subsystem 3 - Part No SW: 4G2 919 610 G HW: 4G2 919 610 G
Component: E380 BDT C7 H20 0250
Serial number: 90349QBN000S5
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 2010
2 Faults Found:
1597 - Data Set Implausible
B2012 00 [009] - -
[Control module (data record download) - implausible data record for language]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:38
Voltage terminal 30: 12.1 V
1598 - Data Set Implausible
B2012 00 [009] - -
[Control module (data record download) - implausible data record for visible MMI system languages]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:38
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0511
Coding: 010F1C004001628202080002
VCID: 47CB581E0FA89C036A8-8012
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 C HW: 4H0 907 273 C
Component: RDKBERU25 H10 0820
Serial number: 10000000004371
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0380
Revision: 11001001 Serial number: 82330JG0382160
Coding: 0218000101000000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
ROD: EV_CamerSysteTopViewAUDI.rod
VCID: 2F3B10BE87982443428-807A
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0152
Revision: 14005001 Serial number: 068701139
Coding: 093205C030
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0511
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 N HW: 4G0 919 604 N
Component: HeadUpDisplay H09 0306
Revision: 00000000 Serial number: 00000000000000
Coding: D68000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853) Labels:* None
Part No SW: 4G0 907 547 B HW: 4M0 907 547
Component: NV-ECU-Gen3 H10 0117
Serial number: 636636000201706
Coding: 301100
ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 2D070AB68D945653704-8078
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 A HW: 4G0 980 552
Component: NV-CAM-Gen3 H05 0007
Serial number: 639589400A1701800098
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H28 0081
Revision: -------- Serial number: 262130025421000
Coding: 6A160000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C0107B2B68E5F5B67A-8078
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Component: ACC3 H21 0053
Coding: 7E02010102
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 270BF89EAF687C038A8-8072
3 Faults Found:
88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_SLOW_MISALIGNMENT]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 33196 km
Date: 2022.08.25
Time: 21:50:27
Control Module temperature: 20 °C
Voltage terminal 15: 14.184 V
Velocity_vehicle_reference: 12.02 m/s
Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_FAST_MISALIGNMENT]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 33003 km
Date: 2022.08.20
Time: 19:46:33
Control Module temperature: 24 °C
Voltage terminal 15: 14.416 V
Velocity_vehicle_reference: 34.69 m/s
Longitudinal_acceleration_vehicle_reference: 0.10 m/s²
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_PRE_MISALIGNMENT]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:35
Control Module temperature: 37 °C
Voltage terminal 15: 11.938 V
Velocity_vehicle_reference: -0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H34 0090
Serial number: 005002452203177
Coding: 04C23A1B0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H16 0080
Coding: 0066E608031F0376070308004240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F16C691AC32B354C-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813008133201
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X_AU57.rod
1 Fault Found:
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:38
Address 47: Sound System (J525) Labels:* None
Part No SW: 4G5 035 223 E HW: 4G5 035 223
Component: MIB2_amp_P H03 0440
Serial number: 00000000023009
Coding: 01756208018AF02A5A0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 2411EF92DE5E971BAFA-8070
End----------(Elapsed Time: 02:47, VBatt start/end: 14.4V/14.5V)-----------
Audi RS6 Performance Fault. Advice/Help needed
Stian5jorg
Re: Audi RS6 Performance Fault. Advice/Help needed
Did you found the problem and fix the car?! Have the same thing on mine 2017 performance now. 29 same engine faults as you, all Linked to SA6 fuse. Audi workshop have a hard time find out what makes the fuse brake….
Stian5jorg
Did you found the problem and fix the car?! Have the same thing on mine 2017 performance now. 29 same engine faults as you, all Linked to SA6 fuse. Audi workshop have a hard time find out what makes the fuse brake….Mo-Rs wrote:Hi Guys in need of some help. Had my 2017 Audi RS6 performance over a year been flawless no issues.
Thanks in advance.
Details Below
www.Ross-Tech.com
47
29 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:38:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:39:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:39:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35564 km
Date: 2022.12.01
Time: 13:39:41
Coding: 000001
Revision: 00002001
Cannot be reached
4 Faults Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 15
Mileage: 35162 km
Date: 2022.11.03
Time: 20:48:30
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 27
Mileage: 34810 km
Date: 2022.10.20
Time: 19:35:31
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 27
Mileage: 34810 km
Date: 2022.10.20
Time: 19:35:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 16
Mileage: 33724 km
Date: 2022.09.13
Time: 19:16:19
Coding: 0045F7
Coding: 02006D
Coding: 020300
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 27
Mileage: 31961 km
Time Indication: 0
Date: 2022.07.17
Time: 12:09:55
Coding: B83B27
Coding: 7E02010102
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 97
Mileage: 33003 km
Date: 2022.08.20
Time: 19:46:34
Coding: 0000000
Coding: 0000FD
Coding: C0ED07481C
Voltage stabilizer:
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 27
Mileage: 35579 km
Date: 2023.01.16
Time: 18:29:56
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:34
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 010100
Coding: 22
7 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 17
Mileage: 35429 km
Date: 2022.11.17
Time: 20:11:16
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 21
Mileage: 34962 km
Date: 2022.10.24
Time: 21:44:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 17
Mileage: 33735 km
Date: 2022.09.13
Time: 19:56:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 20
Mileage: 34723 km
Date: 2022.10.18
Time: 18:20:20
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 17
Mileage: 35422 km
Date: 2022.11.17
Time: 20:05:04
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:35
Freeze Frame:
Fault Priority: 3
Reset counter: 242
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:35
ROD: EV_SARA2.rod
Coding: 040312
Coding: 040312
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 242
Mileage: 31931 km
Time Indication: 0
Date: 2022.07.16
Time: 17:43:34
Coding: E01F00
Coding: E01F00
Coding: E01F00
Coding: E01F00
Data carrier:
2 Faults Found:
B2012 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:38
B2012 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:38
Coding: 093205C030
Coding: D68000
Coding: 301100
Coding: 6A160000
Coding: 7E02010102
3 Faults Found:
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 33196 km
Date: 2022.08.25
Time: 21:50:27
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 33003 km
Date: 2022.08.20
Time: 19:46:33
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:35
ROD: EV_BC7.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 31931 km
Date: 2022.07.16
Time: 17:43:38
