I have a year 2000 Audi s6 where the mirrors have stopped working.
Initially the switch was damaged and that may have caused it but that may have been a coincidence and I had just not tried to move them.
Anyway with a new switch there is no difference. I have a wiring diagram for this car and checked fuse f5 which is ok and has 12v on ignition. There is no power at the switch however which it should go to directly I believe. Is there a connector somewhere?
I can’t see how it can be disconnected unless it is under the drivers side carpet where the gearbox Ecu had to be replaced due to water.
The other option is the control module a187 on my diagram. Does anyone know where that is located as I don’t see it beside the relays etc. Under the floor I presume.
Any help would be great
Mike
Electric mirrors not working
Mike2drummond
Re: Electric mirrors not working
Apologies I was not getting a good contact and there appears to be 8.5v at the switch so I suspect the control module is faulty.
Users browsing this forum: No registered users and 9 guests
