C5 RS6 Avant - Avus silver
Promech
Post by Promech » Mon Jan 17, 2022 2:53 pm
2004 C5 Audi RS6 Avant finished in Avus silver with black leather interior
77k miles
Gearbox replaced in 2015 @ 70238
Bose, Sat Nav, electric heated seats,
Tracker Monitor Fitted
MRC tuned 510 BHP with gearbox remap
Cat back Milltek Exhaust System
H&R coilovers
Looking for £14,000
Service History and Repair work.
9/11/2004 Audi AVS service at Boulton Audi 2010 miles
9/6/2006 Audi AVS service at Boulton Audi 14973 miles
28/5/2007 Audi AVS service at Aberdeen Audi 21995 miles
18/3/2009 Audi AVS service at Aberdeen Audi 33440 miles
8/10/2008 Aberdeen Volks Centre Ltd – 33799 timing belt replacement, water pump, coolant,thermostat, brake discs and pads .
11/11/2009 Aberdeen Volks Centre Ltd - 37783 mikes Diagnode ESP fault, new brake light switch fitted.
22/3/2010 Aberdeen Volks Centre Ltd - 39410 miles Major service
24/3/2011 Auto Technic Independent Audi Specialist - 44446 miles major service, CV boot, brake fluid change.
02/08/2011 Auto Technic Independent Audi Specialist – 47758 miles Gearbox service.
08/08/2011 Auto Technic Independent Audi Specialist – 47809 miles Replace propshaft and driveshaft seals, replace offside front window regulator.
25/04/2012 Auto Technic Independent Audi Specialist – 51643 miles Service
7/8/2012 Auto Technic Independent Audi Specialist – nearside rear window regulator replaced.
15/5/13 Auto Technic Independent Audi Specialist – 57020 miles Service
25/11/13 Auto Technic Independent Audi Specialist – 61701 miles Replace Front brake discs and pads, replaced fuel pump, replaced upper front suspension arms and upper links.
28/11/14 Promech – 68526 miles Major service Using OE parts Oil filter, air filters, cabin filter, spark plugs, fuel filter and fully synthetic oil supplied by VAG.
28/10/15 Promech – 71642 Replaced Automatic gearbox with unit rebuilt by Chester Automatic Transmission Centre. All oil lines cleaned and new Genuine Audi oil and filter used in gearbox.
Also replaced when engine was out ; New radiator, turbo oil lines, rocker cover gaskets and seals, timing belt kit, water pump, coolant, thermostat, auxillary belt, both lower suspension arms.
Will add the rest of the service history later
