2.7T allroad - SOLD
luke-s07
2.7T allroad - SOLD
Post by luke-s07 » Tue Nov 23, 2021 5:22 pm
For sale is my 2005 Audi A6 Allroad 2.7 bi turbo manual with a spec as follows:
Borg Warner RS6 turbos modified to fit.
Custom intake with AEM heat sheild, 034 motorsport RS4 Maf and K&N filter.
MRC front mount intercooler with custom pipe work.
3" decat downpipes into 2.75" RS6 exhaust.
RS4 +15% clutch kit with TTV single mass flywheel.
RS4 turbo inlet pipes.
034 motorsports engine mounts.
034 motorsports snub mount with bracket.
034 motorsports gearbox mounts.
Walbro 450 fuel pump with 034 motorsports mounting bracket.
Bosch ev14 550cc injectors.
Fluidamper crank pulley.
BES engine code with metal throttle body boot and TFSI coil packs from factory.
Hotchkiss anti roll bars front and rear.
Awe drive train stabilser.
Brembo 18z front calipers with J hook discs and brembo pads.
B7 S4 rear brake calipers with A8 J hook discs.
Judd T311R lightweight alloy wheels
H&R 30mm spacers all round.
Custom carbon engine covers.
Custom speedo dials with allroad sport badge.
JHM weighted gearknob.
Full screen Audi satnav.
Bilstein B14 coilover conversion with billet coilover spacers.
The car is currently running a base map as I was bedding the clutch in, which is now done, so final mapping will be needed and will see 500+bhp. The car is on 118k miles with full service history, some at garages and some self service as I am a mechanic. The car does need a little work to bring it up to perfect condition:
Front plastic arch extensions are worn down slightly from when my compressor failed and the wheels rubbed, a set will be included in the sale which need painting.
Has a bit of lacquer peel on drivers door, 50 pence size, and rear arch extensions.
Wheels need a refurb.
Front calipers could do with a repaint.
Lower front bumper has a bit of damage from where the compressor failed
Needs a drivers side outter CV boot.
Needs front anti roll bar link bushes, a set of powerflex black will be included.
The mot runs out on 17th of December, however I will change the CV boot and bushes and have it Mot'd if the asking price is met.
The reason for sale is I'm looking to buy my own house and need funds for a deposit. My asking price is £5000.
Please note private plate is not included in sale. ImageImageImageImageImageImageImageImageImageImageImageImageImage
Sent from my VOG-L29 using Tapatalk
c4v8
Re: 2.7T allroad
Post by c4v8 » Sat Nov 27, 2021 4:47 pm
Hi, where abouts are you regarding a view on the allroad
regards
chris
Users browsing this forum: No registered users and 165 guests
