Hi all
Bought an rs4 in feb and it’s been stored while we move, however can’t find the tyre pressures any where.
Can someone tell me the correct pressures please.
Also when searching online for tyres, put reg in and it comes up with a different size tyre that’s fitted now, have got 275/30/zr20 fitted, is this the correct size?
Tyre size and pressures
Re: Tyre size and pressures
There should be a Sticker on the driver's door. Standard is 265/30/20
Sent from my Pixel 5 using Tapatalk
Thank noidea, never thought to look there. Guessing the tyre size difference won’t make a difference? Why put a wider tyre on?
Who knows why but sometimes it can be down to availability. I would always stick to the recommended size though. I think the B9 has 275s fitted as standard
Agreed, I think it’s all rather tight on clearance (not that 10mm should make a big difference) to the strut etc.
Stick to standard and remember to set the tyre monitor when you are done
2018 RS4 B9 Carbon Edition
2014 RS4 B8
2014 RS4 B8
Thank you both, will check everything next time I get to the car
