Everyone’s favourite topic- DRC
4.2 V8 32v FSI - 444 bhp
Scammo1
Post by Scammo1 » Sat May 29, 2021 12:24 pm
If there is a leak in the front pipe, does anyone know if that will also effect the rear?
Is the oil shared throughout the whole system or split front and rear I.e would a leak in the front end up draining the whole system?
Noticed suspension feels a bit bumpier than usual and on inspection there seems to be a bit of clear oil under car near front drivers wheel.
This is after Audi changed the DRC oil and re-pressurised and inspected the system less than two months ago!!!
hindsight
Re: Everyone’s favourite topic- DRC
Post by hindsight » Sat May 29, 2021 12:28 pm
Others will know better than me but I thought they were connected diagonally. So front nearside to rear offside etc.
JamesBaby
Post by JamesBaby » Sat May 29, 2021 1:52 pm
Yes connected diagonally.
Sounds like you have a leak and will need re-doing.
Scammo1
Post by Scammo1 » Sat May 29, 2021 4:24 pm
It is safe to drive- albeit very gently?
Assume a leak will just mean DRC isn’t working and it will be wollowy?
Rugslasher
Post by Rugslasher » Sat May 29, 2021 7:52 pm
That told me not to drive as it’s can damage shocks & centre valves , I’ve got a full set of low miles pipes & pair of rear shocks if needed 👍🏻
Scammo1
Post by Scammo1 » Sat May 29, 2021 8:00 pm
Thanks!
It goes to a local specialist I trust in Tuesday. Car is still under warranty so hopefully that will cover costs but if not I’ll let you know!
Am certain this is Audi’s f-up. Don’t trust them to fix it properly but once confirmed by specialist they are going to get both barrels!
Scammo1
Post by Scammo1 » Thu Jun 03, 2021 4:57 pm
So the reservoir on my osf shock is weeping and the whole thing needs to be replaced.
Rear near side shock also isn’t working as expected but the garage suspects this could be because all of the oil has drained and the DRC needs repressurizing.
I hope that’s the case but does it sound plausible to you guys? I know shocks are linked diagonally.
Rugslasher
Post by Rugslasher » Thu Jun 03, 2021 8:06 pm
Yeah sounds right my rear was knocking opposite to front...........
Just get some KW’s on 😂
mines a different car now & no listening for knocks all the time
