Hi,
Relatively new owner here and first time poster...
Today I booked my Avant in at CRS to have the DRC removed and replaced with Koni shocks, due to the near side rear failing and leaking oil onto the drive...
Dave.
The Best Hunting Boots of 2021
Re: Cool What did you do to your B7 RS4 today?
I’m also a new B7 RS owner - cabriolet to take advantage of the lovely Scottish summer
, below is my wee list :-
1. New shifter knob
2. Changed DRLs to clear bulbs
3. New plastic clutch pin to stop the clutch click
4. Oil, diff and box fluids
5. Spark plugs
6. Test/clean air box flap and manifold flap with VCDS.
7. New drivers Seat belt buckle
8. New G65 Aircon sensor for aircon and regas.
9. Interior and rear plate bulb change to LED’s
10. ECS H pipe install for a slightly better note.
11. Full detail, wax and seal.
12. New centre caps and bolt covers
13. New steering wheel lower trim with badge.
Think that’s about it, future bits as below:-
1. Potential suspension DRC is in good shape at the movement but will probably die at some point. Still undecided PSS9’s or the Komi option for a better ride??
2. New oil cooler probably the forge kit
3. Clutch & fly. OEM or Sachs.
1. New shifter knob
5. Spark plugs
washed it, put some fuel in it, and now trying to finally make my mind up about retaining DRC or switching to coilovers!
Hey Lewbo my RS4s got an annoying clutch click at the moment. How did you know it was the clutch pin? I was thinking maybe one of the switches. Mine goes away after driving for a little while.Lewbo wrote:I’m also a new B7 RS owner - cabriolet to take advantage of the lovely Scottish summer, below is my wee list :-
1. New shifter knob
5. Spark plugs
Users browsing this forum: No registered users and 97 guests
