TPM
2.9 V6 24v TFSI - 444 bhp
Swegen
TPM
Post by Swegen » Sun Apr 25, 2021 12:00 am
Hi, just trying to work our if am missing something on my B9.5. In the RS monitor on MMI the tyre pressure system is always unavailable. Checking the description of the TPM in the configurator it says 'Air pressures and temperatures of wheels can be displayed in the driver information system of in the audi virtual cockpit'
Brooner
Re: TPM
Post by Brooner » Sun Apr 25, 2021 6:55 am
Its possible that the system is not fitted as it was an option on the pre face lift
RS4John
Re: TPM
Post by RS4John » Sun Apr 25, 2021 9:35 am
The MyAudi App will reveal the spec of your vehicle.
TBH the TPM is a pants implementation - one could reasonably expect the software to compensate for tyre temperature (pressures rise as the tyres get warmer), however it doesn't so the pressure readings constantly change.
2020 F3 RSQ3 Std, 400PS, Daytona Grey/black Ara blue interior, Pano, C&S pack, Red calipers, HBA, TP monitoring, 5yr Warranty, Cete AVC, EBC Redstuffs
Gone, 2016 8U RSQ3 Performance
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Dannyboy123
Re: TPM
Post by Dannyboy123 » Sun Apr 25, 2021 6:42 pm
Just look to see if your air valves are silver or black. Srd rubber black valves means you don't have the tpms system.
Markp
Re: TPM
Post by Markp » Sun Apr 25, 2021 9:36 pm
Don’t they all have TPMS? But not all have the pressure display on MMI (which was an option on early cars IRRC).
RS4John
Re: TPM
Post by RS4John » Mon Apr 26, 2021 12:14 am
There are two kinds of TPMS, one uses the ABS sensors to determine if the tires rolling radius has changed (rubber valve stems) and the second, more expensive version (metallic valve stems) has sensor box in each wheel that wirelessly communicates temp and pressure data to a display in the virtual cockpit.
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Swegen
Re: TPM
Post by Swegen » Mon Apr 26, 2021 2:33 am
yeah my valve stems are rubber so the TPM that came default with with NZ config will be the cheaper one, thanks for clarifying.
Dannyboy123
Re: TPM
Post by Dannyboy123 » Mon Apr 26, 2021 6:28 am
All new cars have a tpms system by Law I think. There are two types though. A direct tpms system has sensors in the tyres and indirect uses the cars abs sensors to calculate the loss in pressure.
Users browsing this forum: No registered users and 10 guests
