Exhaust centre resonator delete
2.9 V6 24v TFSI - 444 bhp
Tweaky
Post by Tweaky » Sun Mar 07, 2021 7:12 pm
I have just had some centre resonator delete pipes fitted to my car.
HG Motorsport BULL-X 2.75" Non-Res Centre Mid Pipes Delete For Audi RS4 RS5 B9
They are brilliant, it sounds so much better, especially in dynamic and is a nice easy and cheap fix. I haven’t heard any drone yet and certainly non in quiet mode. The pops and crackles are quite a bit louder, and it sounds very meaty on the cold start. Unfortunately I couldn’t get the Cete Automotive valve controller fitted at the same time as the chap that fitted it was no it too confident about cutting wires in the wiring loom. I need to look into that one a bit more. Has anyone on here got one that they fitted themselves?
MY18 RS4 Carbon edition in Nardo
Avantgarde
Re: Exhaust centre resonator delete
Post by Avantgarde » Sun Mar 07, 2021 7:42 pm
I didn’t have to cut any wires when installing the Cete controller.
I also find that with the exhaust valve open using the Cete controller I get drone between 2000 and 2500 rpm on the stock sports exhaust, and am looking for ways to reduce the drone.
Tweaky
Post by Tweaky » Sun Mar 07, 2021 8:40 pm
Ok so how did you connect the orange wires into the loom? Also if you have you MMI set to auto does it not let the car system work the valves as per normal? Is it not only when you force the valves to be open all the time with the traction control button that you have that problem?
simundo777
Post by simundo777 » Sun Mar 07, 2021 9:16 pm
Very interested in doing this to mine, do you mind me asking what the total cost was?
Presume the sound increase is well worth the outlay?
Current: B9 RS4 Navarra Blue
Gone: B8 RS4 Nogaro Edition. BMW 1M. Cayman 981S. E90 M3. E46 M3 CS
Tweaky
Post by Tweaky » Sun Mar 07, 2021 9:19 pm
I bought the pipes on eBay for £2xx and it cost me £40 to a friend to fit them. Money very well spent, I would not hesitate to do it again.
Avantgarde
Post by Avantgarde » Mon Mar 08, 2021 1:17 am
You merely connect to the orange wires, not cut them.
I get the drone when the valves are forced to the opened position.
