Coil Pack connector removal tips?
Hi All,
Just went to replace my plugs but gave up after a while as one of the coil pack connectors was proving to be a pain to remove.
Now, I managed to loosen 3 of the 4 on the driver's side using the push towards coil pack, press on the clip till it clicks, and pull down method.
But the 3rd's being a PITA.
I tried a few times with a screwdriver in the clip and the connector clicked but still wouldn't move.
Didn't want to go overboard with the screwdriver so as not to snap anything.
Any tips?
Mike
Any tips?
Mike
Re: Coil Pack connector removal tips?
Breaking the connectors is not unusual as the plastic can become brittle due to heat and and age. The method I use, if they’re being difficult, is to push them in fully, then push the clip down and wiggle/pull at the same time. You might need to do it a few times before it works. If you push them in and hear a very faint click, you simply slide them out.
Good luck.
Good luck.
Cheers Kenny,
I'll have another go at them this morning.
Found this video where he uses a pick so I'll try that as well.
https://www.youtube.com/watch?v=srBS3_Q82rY
ta
Mike
ta
Mike
Success!
Using the method in the video above with the pick...
Worth giving it a go if your connectors are being stubborn
ta
Mike
ta
Mike
If you end up breaking them the part number is 4B0973724. There’s a lot on eBay.
Edit: well done I didn’t refresh my browser!
And do yourself a favour; get a good quality VAG electrical connector tool. If you have a quality one, it takes seconds to remove the individual junior power connectors from the housing and swap them over.
I use a mini 90 degree pick on all these types of connector, makes them so much easier to remove
2007 B7 RS4 Saloon, Phantom Black, Forge Oil Cooler Kit, custom home made air feed, H&R Coilovers, H&R anti roll bars, 10mm H&R Spacers, Milltek decat downpipes, Milltek Non Res Valved Exhaust, Reyland Motorsports front & rear discs with Hel braided Hoses, full underbody overhauled inc powdercoated subframes and arms, 034 solid subframe bushes and every joint, arm or bush replaced.
All done now and car starts with no warning lights etc.
Oil & filters done as well.
It's on blocks at the mo while my wheels are getting refurbed so I'll take it out for a spin towards the end of next week hopefully.
I used one of these to remove the coil packs:
https://www.ebay.co.uk/itm/T40039-Ignit ... SwkcVe1ae7
Well worth the small outlay IMO.
Cheers for the advice.
Mike
Mike
Users browsing this forum: Bing [Bot], Google [Bot] and 395 guests
