How Solar Panel Can Power A Car Battery: Charging the car battery with solar panels
solarpanelsonhouse
Post by solarpanelsonhouse » Fri Feb 05, 2021 7:10 am
How Solar Panel Can Protect Your Car battery?
If you have a visit far from a normal civilization or a campaign aria you don't need for worried about your car battery charging. A 12v solar panel charger is an easy solution for car batteries almost anywhere on the planet. This solar panel can power other devices as well.
Almost all motorists are familiar with the problem of discharging the car battery at the most inopportune moment. The reasons may be different.
The music was turned on for a long time, you forgot to turn off the headlights, the car was standing for a long time. Very lucky if in such a situation you will be given a light the owner of another car. Some even carry a spare battery pack. In such situations, the Solar Panel can help out .
Solar Panel For Car Battery: 12V Solar Panels for Car battery Charging
A 10-watt solar panel can charge a 12V battery, but the panel must be a 13.5 Volt output with a 10-watt specification.
Let's find out which panels you need to pick up so that you can charge the car battery.
Take a battery with a capacity of 60 Ah, a voltage of 12.6 – 6 cans connected in series with V = 2.1 V. The charge current is 0.1 * 60 = 6 A. Charging time up to 12 hours. Such a charge can provide a panel with a power of 60 W, with a controller installed.
Benefit of solar car battery charger with charge controller
  • Prolong Battery life: Solar car battery chargers provide a steady stream of power. It prevents complete discharges and continues charging batteries at optimum level which confirms batteries healthy long life.
  • Convenient and portable: Solar panel it's individual power source offer incredible freedom of movement. They are safe, compact and highly portable, provided charging facilities in any discharging situation, no matter where you are? Just confirm to do is to place the solar unit under sunlight and proper angle.
  • Cost-efficient: Solar chargers will serve you a long time up to 25 years will save you quite some money keep you worried less. It's all free electricity source which avoids getting high electricity bills.
Return to “General Car Chat”
