Stage 2 with Wagner Intercoolers
5.0 V10 50v biturbo - 571 bhp
Phuketpaul
Post by Phuketpaul » Sun Nov 15, 2020 10:00 am
Just got my car (2010 RS6 plus avant) back from MRC after lots of work (oil seal, coolant pipes, gearbox service, ARBs) and stage 2 tune.
On removing the front of the car they discovered damage to the nearside intercooler (leaking) and auxiliary water-cooled so decided to get the wagner intercooler kit which replaces both intercooler and watercoolers
The original watercoolers are removed and replaced by 2 larger watercoolers fitted in front of the main radiators and the the much larger intercooler fit where the originals were. The bumper bar is also replaced.
Original
[attachment=0]20201027_173729.jpg[/attachment]
With Wagner kit
[attachment=3]20201113_125101.jpg[/attachment]
[attachment=2]20201113_125842.jpg[/attachment]
As the engine was out I decided to go for MRC downpipes instead of just secondary cat delete.
At the moment I have left the stock cat back exhaust in place and this is limiting the power above 5250 rpm, but the torque is awesome and the car is still nice and quiet when cruising
747PS @ 5400 and 1059Nm @ 3400 with a lovely fat torque curve
[attachment=1]20201114_112441 1.jpg[/attachment]
2010 RS6 plus Avant, MRC Stage 2 747bhp 1059Nm
2008 Aston Martin DBS Volante
2001 Discovery 2
House89
Re: Stage 2 with Wagner Intercoolers
Post by House89 » Sun Nov 15, 2020 9:08 pm
Lovely work, I've been thinking a lot about this as my intercoolers are weeping a little.
MRC had mine at 715bhp 720ft/lb, standard engine apart from air filters and miltek cat back.
I'd be hoping for more than 750 with new coolers and down pipes though, or is that the expected figure??
Phuketpaul
Post by Phuketpaul » Sun Nov 15, 2020 9:42 pm
Mine was 747bhp/781ft/lb, the maximum power was held back by the stock cat back exhaust, you could expect a significant increase with your exhaust. I may well do my exhaust and get it mapped again
2001 Discovery 2
House89
Post by House89 » Sun Nov 15, 2020 10:20 pm
Ahhhh that makes sense then, thanks for the clearing that up.
House89
Post by House89 » Sun Nov 15, 2020 10:29 pm
How do you find the crackle map? I assume you can switch it on and off as I'd be looking at adding it (once my cats are removed) but I don't think it's something you want on all the time.
Phuketpaul
Post by Phuketpaul » Sun Nov 15, 2020 11:25 pm
[/quote]
[/quote]
Love it, but I agree completely, most of the time I have it off, just turn it on when I'm in the mood
2001 Discovery 2
House89
Post by House89 » Sun Nov 15, 2020 11:54 pm
How's it activated?? Do they add a switch in or is it a case of if traction control is off or you're in Sport then it's on?
Phuketpaul
Post by Phuketpaul » Mon Nov 16, 2020 2:20 pm
Switched on when traction is switched off
2001 Discovery 2
House89
Post by House89 » Mon Nov 16, 2020 6:04 pm
Perfect
SR71
Post by SR71 » Tue Nov 17, 2020 11:51 am
Interesting.
I had the MRC Downpipes with secondary cat delete, but otherwise completely stock exhaust and IC's, and wound up with 770hp.
I think Doug did say a Miltek might free up a few more hp....
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Phuketpaul
Post by Phuketpaul » Tue Nov 17, 2020 11:56 am
Interesting.
I was on a full tank of Esso fuel, and Tesco Momentum or Shell V power would almost certainly have liberated more, but decided to leave it as it was and I'll use Tesco fuel when i go back with the exhaust done
I think the intercoolers will probably have more effect in day to day running than quick runs on the dyno
2001 Discovery 2
SR71
Post by SR71 » Thu Nov 19, 2020 10:35 am
Clearly makes a difference then!
I never put anything other than Tesco 99 or Shell V-Power in my car in almost 4 years of ownership....
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Phuketpaul
Post by Phuketpaul » Thu Nov 19, 2020 6:25 pm
Doug said could be over 30bhp difference not using Tesco 99 or V power
2001 Discovery 2
