B7 ‘cold start’ / noise change
Fatneck73
Post by Fatneck73 » Fri Oct 23, 2020 7:00 pm
Hi all
When i start the car, It ticks over at c1400rpm x 60 seconds or so...and then calms down. I believe this is called ‘cold start’. No probs.
What i cant understand is that if i then rev it back to 1400rpm, the noise is nowhere near as ‘deep’. And before you say it, then backbox valves are disconnected.
Soo...whats changing? Are there more valves earlier in the zorst or something else...coz i wanna disable it...sounds awesome when on cold start.
TIA
Ade
coffey555
Re: B7 ‘cold start’ / noise change
Post by coffey555 » Fri Oct 23, 2020 9:35 pm
It is the SAI pump forcing more air into the engine to warm up the pre-cats quickly. Pretty sure it injects more fuel as well to match the increased airflow.
It does sound nice but is a bit loud if you have the centre resonators deleted (in my case, with straight pipes) with the exhaust valves open.
Nothing you can do to get that deeper sound when reving the engine at a standstill. However, you will get it when the engine is working under load (high gear, low revs etc).
Misano Red RS4 B7 Avant
Fatneck73
Post by Fatneck73 » Sat Oct 24, 2020 7:19 am
Yep, im ‘straight pipes’ as well 😜😁
Brill answer, thats very much.
Users browsing this forum: No registered users and 108 guests
