Hi,
As part of my S2>RS2 mods I'll be replacing my rod bearings. The early 3B rods were fitted with a single metal shell, unlike the later ABY/ADU which have a three metal variety. I've been recommended to upgrade the shells to the later type and noticed a few owners have opted for a pair of upper shells in each rod. The reason for this is that the uppers are constructed from a harder material than the lowers. Has anyone tried this or could advise me if it's worth it on a 350 -370 bhp upgrade?
Cheers,
Steve. [img]images/graemlins/24430-audibash.gif[/img]
Rod bearings
markhalligan
Re: Rod bearings
Steve,
I suggest you try this site(if you have'nt already) http://autos.groups.yahoo.com/group/Audi20V_Kruemmer/
Its dedicated building and tuning the Audi I5t engine (you'll need to register).
Regards,
Mark.
Regards,
Mark.
1993 ABY Coupe
Turbonetics Garret/KKK hybrid BB turbo , MTM sport quattro exhaust manifold, Custom fabricated 3" downpipe, seperate wastegate exhaust pipe, Decat, RS2 inlet manifold, RS2 intercooler, RS2 injectors, 5bar-200lt/hr fuel pump, 5bar fuel regulator, Modified crankcase ventilation, 393.4 bhp @ 6798rpm, 356.2lbft (470.19NM) @ 4938rpm at 1.8 bar max boost pressure, mapped 'on the fly' at 28 deg C max ambient temp(hot day) by Mihnea.
18inch BBS RK II split rims,225/40 SO3's, 322mm front rotors with Brembo calipers, 280mm rear rotors with S8 calipers/carriers, Boost/EGT gauge. Whiteline rear anti-roll bar.
