Anti roll bars
Anti roll bars
Is this the correct part for an RS6 Avant? Also whats the script with fitting? Does it require modification?
https://www.awesomegti.com/shop-by-bran ... NAQAvD_BwE
Sent from my SM-G960F using Tapatalk
Re: Anti roll bars
Yep, same part no as mine. I didnt fit mine so cant help re fitting.
Re: Anti roll bars
They are fitted just like the stock ARBs. No modification and no problems installing them.
Re: Anti roll bars
Excellent, I was sure I read something about it fouling on something.
- julianmalc
Re: Anti roll bars
They are the best value for money mod you can do, I was shocked at how the steering had more weight and feel, and it reduces under steer and makes the car more balanced through the corners, I had them fitted by a vag specialist, but when having 3 inch down pipes fitted MRC modded the arb brackets slightly as the ARB was rubbing slightly
Re: Anti roll bars
I fitted them on mine and extra work was need. The front bar need an extra bush between the arb and droplinks to avoid exessive stress on the c link as the front arb is about 20mm too narrow and the casting it installs into need some grinding for clearance of the locating collar. The rear needed spacing back 6mm with spacer plates as the ends of the rear arb touched the drive shafts. My car is lowered, so that could be why i need addition work
Re: Anti roll bars
Were the extra bits you used custom or off the shelf? Just ordered the KW springs and H&R ARBs.A20LEE wrote: ↑Mon Nov 16, 2020 6:37 amI fitted them on mine and extra work was need. The front bar need an extra bush between the arb and droplinks to avoid exessive stress on the c link as the front arb is about 20mm too narrow and the casting it installs into need some grinding for clearance of the locating collar. The rear needed spacing back 6mm with spacer plates as the ends of the rear arb touched the drive shafts. My car is lowered, so that could be why i need addition work
What setting do people recommend for the bars?
Re: Anti roll bars
I just ordered these myself. It appears the front is 32mm as oem, while the rear +3mm thicker.
I intent to use the middle setting for both front and rear
Sent from my SM-S908B using Tapatalk
