Help with fault code - 01314 - Engine Control Module
SimonS4MTM
Post by SimonS4MTM » Fri Sep 11, 2020 7:06 pm
Hi all,
It's been a very long time since I have posted, but I am looking for some help.
My car has been sat away for quite some time, used for around 160 miles in the last 12 months. A few weeks ago I took it out for a spin and had engine cut out at high revs, over 6000 rpm. TC and EPC lights came on dash. Engine kept cutting out at high revs a few times when trying before i got home.
Found multiple fault codes with VAG-COM and cleared them.
Drove the car 1 week later and had the same engine cut issue at high revs. ABS fault code and ECM fault code logged with VAG-COM. Cleared the codes again.
Drove the car again today and engine cut again at high revs. ECM fault code logged again.
Fault code is;
1 Fault Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x5C00
Hex Value: 0x4006
Hex Value: 0x0025
Hex Value: 0x01A3
Hex Value: 0x0001
This fault code has logged every time the engine has cut out.
I have searched the web and found a few suggestions. Anyone else have any experience of this and have anything to add.
Thanks in advance, cheeRS,
Simon
irishmike
Re: Help with fault code - 01314 - Engine Control Module
Post by irishmike » Sat Sep 12, 2020 12:29 am
That seems very familiar to me..
I'd need to double check my logs, but the code rings a bell and the symptoms were the same.
Long story short, I needed two new ECUs...
Hopefully it's not the same for you.
Sent from my HD1903 using Tapatalk
Simon_355
Post by Simon_355 » Sat Sep 12, 2020 10:35 am
Oh crumbs.
I hope that’s not the case.
I have heard some people change relays for the ECU’s
irishmike
Post by irishmike » Sat Sep 12, 2020 11:03 am
Yeah, that was the first course of action on mine but it did not solve it, so was new ECU time.
Now this was a main stealer and an independent might have had a different approach.
SimonS4MTM
Post by SimonS4MTM » Sat Sep 12, 2020 6:37 pm
Anyone else got any advice. If not then I feel a trip to MRC might be needed.
MIDZ
Post by MIDZ » Sat Sep 12, 2020 6:57 pm
Maybe a bit of a long shot, but what about fitting a new MAF sensor? I've heard of it bringing on the TC lamp permanently when it goes faulty, and possibly with the car not getting used its not reading properly now....just a thought as an easy part to replace, and not too expensive compared to ECU's.
SimonS4MTM
Post by SimonS4MTM » Sat Sep 12, 2020 6:59 pm
Cheers MIDZ.
The MAF was new just over two years ago just before a carbon clean at MRC.
MIDZ
Post by MIDZ » Sat Sep 12, 2020 7:13 pm
Ah ok Simon, that kind of rules that out then...strange it cuts out at 6K? maybe even try a vacuum function test with your VCDS and check everything works as it should
SimonS4MTM
Post by SimonS4MTM » Sat Sep 12, 2020 7:16 pm
Anywhere between 6 and 8k.
Vacuum test is worth a go. Not done it before but I assume it straight forward with Vagcom?
Will take a look at the vac hoses for the exhaust valves that I blocked up a few years ago also.
MIDZ
Post by MIDZ » Sat Sep 12, 2020 7:29 pm
I've done it a couple of times and followed the good write up on here under the FAQ's thread. It's not a difficult test to run through
SimonS4MTM
Post by SimonS4MTM » Sat Sep 12, 2020 7:30 pm
I will take a look
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 328 guests
