Unidentified noise - help
5.0 V10 50v biturbo - 571 bhp
Doug_RS6
Post by Doug_RS6 » Sun Sep 06, 2020 1:03 pm
So I'm trying to identify this noise. It comes from the offside front and only seems to appear after the car has some heat in it. The noise occurs when the suspension travels or when the steering is turned. There is no play in any joints. I've attached a video of the noise.
https://youtu.be/_jtpw3QRx1k
Sent from my SM-G960F using Tapatalk
zex
Re: Unidentified noise - help
Post by zex » Sun Sep 06, 2020 7:14 pm
Bad strut bearing?
Doug_RS6
Post by Doug_RS6 » Sun Sep 06, 2020 7:16 pm
See I had wondered but being that it's double wishbones. The strut doesn't rotate. I've order new track control arms and anti roll bar links as they look a bit worn.
Doug_RS6
Post by Doug_RS6 » Sun Sep 13, 2020 4:07 pm
Turns out that it was a bad lower ball joint on the track control arm.
cammmy
Post by cammmy » Fri Sep 18, 2020 10:46 am
Glad you found it. Are they replaceable or is it like other modern cars where the whole arm has to be done?
Doug_RS6
Post by Doug_RS6 » Fri Sep 18, 2020 12:31 pm
Whole arm replacement. Not massively expensive and a simple enough job with basic tools.
Users browsing this forum: No registered users and 74 guests
