Hey everyone, just bought a 2014 RS5 Cab a few weeks ago and have been chasing the wheel balance since I bought it. Come to learn, the driver rear was a runout tire, so worked with the dealership to get new tires I had installed back home. I got Conti extremeContact’s. Ive learned about RoadForce balancing and it’s all the Shop is doing now. Regardless, I’ve been back to the Shop 3 times, they replaced one tire because they could t get it below ~55. New tire was able to get down to ~11, but now they are telling me they couldn’t get another below ~37 so they are ordering another new one for another corner. They showed me one rim that you can visually see the “out of round” one of the front rims are on the spinner, so am going to get with a local rim repair Shop I’ve used for a car of my parents.
Is this a common problem for anyone that’s got an RS? I’ve had 2 S5 Cab’s before and never had a problem with those like I’m having now.
Help!! I’m starting to lose it and just want to enjoy my car without body shake between 55-70. Doesn’t seem unreasonable right!?
Wheel Balance
- IchBautAuto
Re: Wheel Balance
Looking over your comments, I can't see that it is the car at all. You have had two tyres that apparently couldn't be balanced but you imply that the replacements were OK. That's a tyre issue and a bit of a problem if high performance tyres are faulty to that extent. I recently had a problem with the old style Pirelli P Zero in the RS4 section.
One wheel out of round could easily be some pothole or other obstruction struck at speed. I wouldn't place any credence on a visual observation with the rim being spun. You need a dial indicator to see if it is out of round and by how much and whether it is radial, lateral or both.
So, to repeat myself, I really cannot see this is a problem with your car at this point in time, faulty tyres and a bent wheel atm.
Re: Wheel Balance
I appreciate that that feedback, the Shop has only replaced one tire and I’m still having issues, but they are ordering another and I’m also taking it to a wheel Shop to get that one rim repaired in hopes it helps.
I am hoping that it is just the faulty tires and rim, but I’ll find out this week. Thanks for your help/thoughts!
