Engine faults 7038 and 8113
4.2 V8 32v FSI - 444 bhp
badger3x
Post by badger3x » Sun Mar 01, 2020 8:41 am
Hi everyone,
picked up a second hand MY 14 RS4 (B8/8K) Avant at nearly 74000km just a month and a half ago. Been running fine
but popped up an orange check engine light yesterday. Haven't really found it causing me issues (maybe feels a little
a little lumpy at times, as in some sort of short knock vibration coming from the engine on idle (but not fuel style knock)). Running 98 RON so i dont think fuel
quality is an issue.
Meanwhile ran the ROSS Tech HEXNET/ VCDS over it and came up with two errors:
7038 - Thermostat for Mapped Engine Cooling (F265)
8113 - Performance Malfunction in Cooling System
(please see full scan results below)
The priority codes say take it into the Shop asap (but not stop driving right now)
Im pretty confident it was the second one which caused the check engine light to come on.
Can someone give me an idea what I am up against here - before I take it in to Audi and they try to sell me a whole new engine or car?
Many thanks
Saturday,29,February,2020,14:11:54:57122
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 19.6.2.0 HEX-NET CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: xxxxxxxxxxxxxx License Plate:
Mileage: 76090km-47280mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 22 36 42 44 46 47 52 53
56 5C 5F 62 6C 6D 72
VIN: xxxxxxxxxxxxxxx Mileage: 76090km-47280miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 E HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04---
Coding: 1225003225C6000A3000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560E 001002
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E30F4A5A1A897BF95-806B
2 Faults Found:
P0599 00 [047] - Short to Ground
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 73604 km
Date: 2020.01.09
Time: 13:11:38
Engine speed: 4301.50 /min
Normed load value: 19.2 %
Vehicle speed: 77 km/h
Coolant temperature: 88 ∞C
Intake air temperature: 51 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.159 V
Unlearning counter according OBD: 40
CAN status - engine control module-Bits 0-7: 0
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 3
Cruise control switch actuation-Bits 0-7: 0
P2181 00 [232] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 75889 km
Date: 2020.02.23
Time: 06:25:38
Engine speed: 1537.50 /min
Normed load value: 19.6 %
Vehicle speed: 69 km/h
Coolant temperature: 66 ∞C
Intake air temperature: 35 ∞C
Voltage terminal 30: 13.947 V
selected gear-Bits 0-7: 7
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 J HW: 0B5 927 156 K
Component: 0B5 42 FSIRdW H02 0005
Revision: --H02---
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 44C4864DCF44FD6FC3-8011
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 345D2A
VCID: 45C29B49CC7EC467D4-8011
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 HR HW: 8K0 907 064 GR
Component: BCM2 2.0 H13 0641
Revision: 00002001
Coding: 05924000000000000000
VCID: 075E5141B6F21677E6-8053
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Component: KLIMA 3 ZONEN H04 0121
Revision: D1000000 Serial number: 01181120130794
Coding: 4804600000
VCID: 3A38F8B5B580BB9FA9-806F
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000056833501
Coding: 0600001000349FE22D8140C3000019090F9DC70823090201000008004401010200020034000000
VCID: 7AB838B5F5007B9FE9-802F
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 091113 H06 0080
Serial number: SWF13110095292
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21966103
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000000411130334
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 05A84BD6000000000001
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 C HW: 8K0 907 561 C
Component: ACC3 H11 0100
Serial number: 00000000000000
Coding: 003370
VCID: 3228D0956DF043DF61-8067
Address 14: Susp. Elect. Labels: None
Part No SW: 8T0 907 376 HW: 8T0 907 376 A
Component: J250 DRC FahrwerH01 0020
Revision: 00000000 Serial number: 00875015174000
Coding: 0000000
Shop #: WSC 06435 000 00000
VCID: 7CB43EAD3F3445AFFB-8029
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H47 0610
Serial number: 003KFDB2ZHWJ
Coding: 30544435363030303030554A3052384B3053
Shop #: WSC 28842 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 48DC927DF36CD90F2F-801D
Crash sensor for side airbag: driver side:
Serial number: 6334MSME7D53371FR
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME406A110EA
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME5335135CE
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME08371C4ER
Crash sensor for front airbag: driver side:
Serial number: 63732SME7E3725644
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME2B3930780
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MKM0000O
Coding: 0000FF
VCID: 44C4864DC744FD6FC3-8011
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 931 S HW: 8K0 920 931 S
Component: KOMBIINSTR. H35 0564
Revision: 00300000 Serial number: +XM6AAC2G
Coding: B3EF1100DF010008010000
Shop #: WSC 28843 001 1048576
VCID: 3E30F4A5A9A897BF95-806B
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z13A260809
Coding: 80E3031600
VCID: 4CD4AE6DEF14352F0B-8019
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 0515061803
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 001011130001988
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F2ED9E176C26E370E-807B
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000079753676
Coding: 00781B00000000000000
VCID: 3B36FDB1BABA8297B2-806F
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C12205E01410001
VCID: 56E04C0521D87FFFAD-8003
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H39 0507
Revision: 00001000 Serial number: 0015050479
Coding: 100001010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 3424D68D9FE44DEF73-8061
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0317461778
Coding: 01000E2A20B930958330023280000000
Subsystem 1 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS150 H08 0043
Subsystem 2 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J394 PS240 H08 0043
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813022644303
VCID: 2D12C3E974CE1C273C-8079
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: 55E24B093CDE74E7A4-8001
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 10000000296353
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 393AE7B9B886B087A0-806D
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227KB0D7872748
Coding: 040003010000000001
VCID: 26003CC551382F7FFD-8073
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 600213B1900055
Coding: 0022001
VCID: 373EE1814692A6F756-8063
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 754 E HW: 8R2 035 754 C
Component: H-BN-RW H47 0793
Revision: -------- Serial number: 210K$0D7522875
Coding: 120A01010306A9EF6D80CB4E00000403FC0000020000000000
VCID: 393AE7B9B086B087A0-806D
Subsystem 1 - Part No: 8R0 060 884 BN
Component: ROW 2014 0605
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130K%0D2879705
Subsystem 3 - Part No SW: 8T0 919 611 N HW: 8T0 919 611 J
Component: E0380 Bedient H02 0030
Serial number: 00000001686437
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0305
Coding: 010C12204001210001
VCID: 59FA473950C6508780-800D
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08--- Serial number: 525PA8-J3990JL
Coding: 1020007
VCID: 383CE2BD4B8CA98F5F-806D
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
Component: J605 Master H52 0330
Revision: -------- Serial number: 8K9827851A
VCID: 3C34FEADBFB485AFBB-8069
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H52 0330
Serial number: 8K9827852A
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0305
End----(Elapsed Time: 01:54, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Rugslasher
Re: Engine faults 7038 and 8113
Post by Rugslasher » Tue Mar 03, 2020 4:21 pm
Hi I think thermostat is a common fault on these , mines had one looking at the history
Users browsing this forum: Bing [Bot] and 27 guests
