Audi transmission in Limpo mode
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
FaisalRs6c5
Post by FaisalRs6c5 » Wed Jan 22, 2020 3:15 pm
Hi guys,
I am new here i own an Rs6 c5 recently i had loads of issues with wiring and fuel lines took 2 months to sort it. Later when it was sorted i drove the car it was fine initially but after few miles the transmission went in limp mode and wont shift to second gear.
Now i have shown the car to A transmission expert he says its electrical issue and the code i am getting is voltage low 30 etc.
My car did took a very long crank to fire up for first few times. Battary was weak indeed.
Can a bad battery cause the transmission to go into limp mode.
Your help and guidance are welcome.
Regards
Faisal.
HPsauce
Re: Audi transmission in Limpo mode
Post by HPsauce » Wed Jan 22, 2020 9:13 pm
Have you run a VCDS scan? My first suspicion would be the F125 switch, unless the actual gearbox has been behaving oddly in a way that suggests something internal.
FaisalRs6c5
Post by FaisalRs6c5 » Fri Jan 24, 2020 8:25 pm
The transmission is recently rebuild by Dexol. They recon its electrical issue. Now i am thinking of installing a new battery and seeing whats what.
Mark-RS
Post by Mark-RS » Sat Jan 25, 2020 11:31 am
Post in the C5 section, you will get more responses.
avabj
Post by avabj » Fri Oct 30, 2020 5:18 am
make sure your wirings are installed and grounded properly that's the common problem in replacing a new battery or better to take it to audi specialist to give you a real time advise
Return to “Audi S and RS Ownership”
