Heated Steering wheel swap
Sandy-m2
Post by Sandy-m2 » Mon Jan 13, 2020 5:48 pm
Does anyone want to swap a heated wheel for a flat bottom'd face-lift wheel?
The heat is nice but I miss the mode button to change modes.
Its in perfect condition so I would be looking for a perfect flat bottom swap.
Sandy
Current
2016 RS6 C7.5 Performance Sepang
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
and loads of other shitbox's
ShaneyB
Re: Heated Steering wheel swap
Post by ShaneyB » Tue Jan 14, 2020 10:47 am
Sandy
Hi Sandy,
I almost bought a PE with the round wheel with a view to changing it for a FBSW. I spoke to a couple of dealers and two independents and none of them could guarantee the Drive Select button would work when the FBSW was fitted.
Just a fyi.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
dasquade
Post by dasquade » Tue Jan 14, 2020 11:15 am
Drive select button (be it the stock multifunctional combined cluster swap, performance wheel or OEM aftermarket additional drive eslect button) will work on any facelift model....even without coding as the BMC already has the option precoded and ready to be used. If you want the additional drive select notifications on the instrument display, that depends bit on the firmware of the instrument cluster itself. Forgot the actual firmware number they added it, no biggy if that part doesn't work...in worst case you could let it be flashed and upgraded but sometimes tricky...but button function itself works (facelift only). SO if you only after the button, you could easly just swap the right button cluster with the one that has the drive select button (friend of me still has 1 laying around in case).
Sandy-m2
Post by Sandy-m2 » Tue Jan 14, 2020 2:22 pm
I also found out today that the airbags are different so would be a full swap.
Thanks for everyone's input so far.
Current
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
dasquade
Post by dasquade » Tue Jan 14, 2020 6:48 pm
Yeah different airbag between round and flat steeringwheels
Sandy-m2
Post by Sandy-m2 » Tue Jan 14, 2020 7:31 pm
How much would your mate want for it?
Current
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
Sandy-m2
Post by Sandy-m2 » Sat Feb 08, 2020 10:24 pm
Bump
Current
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
Users browsing this forum: No registered users and 164 guests
