Centre box delete
Heardy
Centre box delete
Post by Heardy » Mon Sep 02, 2019 7:00 am
Morning all is there any reason these couldn’t be modified to fit the standard system ? http://vi.raptor.ebaydesc.com/ws/eBayIS ... spheader=1
Is it the fact that the bore size will be the same at the standard exhaust? If so surely i could use some jointing sleeves Or am i just better taking it to an exhaust place
Tia
2007 B7 RS4
Previously
C5 RS6 Saloon Avus, Phase 2 Viper Remap, Wagners, Full Milltek, Hotchkis Arb's, 390mm C6 Brake's, H&R Coilovers
marc1
Re: Centre box delete
Post by marc1 » Mon Sep 02, 2019 9:00 am
Pretty sure that should work and Milltek are the same size as OE, but maybe give Milltek a call to check. Should sound nice with the centre resonator removed.
MIDZ
Post by MIDZ » Tue Sep 03, 2019 8:51 am
Heardy
Post by Heardy » Wed Sep 04, 2019 7:50 pm
What about this for OEM fit?
https://www.supersprint.com/ww-en/audi- ... e--v1.aspx#!/
Thanks for the link, do you have one of these fitted to yours ?
I’ve come across a scorpion one so i was going to ask if its a direct fit/replacement
2007 B7 RS4
Previously
MIDZ
Post by MIDZ » Thu Sep 05, 2019 8:49 am
I still have OEM system, did some searching and came up with Supersprint manufacturer. Not sure if it's good or bad, although it appears to be direct fit to stock system
coffey555
Post by coffey555 » Thu Sep 05, 2019 11:27 am
A good local exhaust fabricator will be able to add straight, x or h pipes to replace the res-centre section for less than the price of the Miltek or Supersprint part, especially once you add shipping and fitting costs.
I went for the straight pipe option, best modification I have done to the car, sounds wonderful with the rear valves always open. No drone, not too loud and has a nice bassy V8 note at low revs and load.
Cold starts are a bit noisy if you still have the cold start function enabled!
Misano Red RS4 B7 Avant
Fatneck73
Post by Fatneck73 » Thu Sep 05, 2019 3:00 pm
Ditto. Love it.
Heardy
Post by Heardy » Sun Nov 17, 2019 9:12 am
Just to update i bit the bullet and went for a Supersprint, great fit and sounds muck better without being too Ott
2007 B7 RS4
Previously
FrazerD
Post by FrazerD » Wed Nov 20, 2019 2:18 pm
You must have more money than sense!
Why did you not go to your local exhaust fabricator and get them to do straight, X or H pipes for a fraction of the price :bash:
Cheers :thumbs:
Users browsing this forum: No registered users and 295 guests
