Rear Pad Change
5.0 V10 50v biturbo - 571 bhp
Jim Haseltine
Rear Pad Change
Post by Jim Haseltine » Sat Aug 31, 2019 10:49 am
I'm fitting new rear disc & pads, I've got the handbrake wound back to the service position but now I'm a bit unsure of the sequence. Do I seat the pads with the pedal and then initialise the handbrake? I may be missing something but the Elsa intructions don't seem clear to me. On non-electric handbrake cars that's the way I'd do it but just want to be certain that I'm not going to screw things.
c3nturi0n
Re: Rear Pad Change
Post by c3nturi0n » Mon Sep 02, 2019 11:24 am
I did mine last year Jim and i followed what you just described, e.g. handbrake in service position, old pads off... new pads in, handbrake on.
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Toady1
Re: Rear Pad Change
Post by Toady1 » Mon Sep 02, 2019 8:37 pm
Yep was a very easy job. Use VCDS to put it into the service position. Whip the pads out, clean the caliper etc, put new pads in, then wind the caliper back out using VCDS. The instructions are all in VCDS info box whilst you do it too.
