VCDS: couple errors and something to tackle on B/H weekend?
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Post by c3nturi0n » Fri Aug 23, 2019 1:44 pm
hi gents,
hope all is well... i recently re-run VCDS on my car and i noticed couple errors that have been on the car last time i run the scan.
Has anyone got any suggestions how to tackle them especially one under module 17 - Instruments?
Thanks.
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 351I+087568647
Coding: 0031002
Shop #: WSC 02556 785 00200
VCID: 264310139112D62ECEF-8073
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001163497
Subsystem 3 - Serial number: 0103.09.080000000100010469ÿ
Subsystem 4 - Serial number: 010469ÿ
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Address 17: Instruments Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 984 E HW: 4F0 920 984 E
Component: KOMBIINSTR. 0900
Revision: 00100000 Serial number: AZ3215DC9
Coding: 2257453
Shop #: WSC 00070 000 00000
VCID: 2F6DF537BEE897663D9-807A
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 12
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 12
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 N HW: 4F0 959 792 N
Component: TSG BF H05 0240
Revision: 00000000 Serial number: iv„
Coding: 0028410
VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 6
Reset counter: 55
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
IanH755
Re: VCDS: couple errors and something to tackle on B/H weekend?
Post by IanH755 » Sun Aug 25, 2019 5:20 am
1. J197 Level control - this is the headlight levelling control and it is a small arm (6in) on the front and rear left side suspension which leads to a small black box. The arm moves with the suspension and the black box reads that motion and uses it to move the headlight beam up/down.
2. KombiInstr - This is the dash cluster, look like your may have been replaced with another. They are coded to the car to try to prevent "clocking" as the cluster hold the mileage info but it means that a genuine swap also causes the same message - no idea how you "code" it to your car though.
Just makes sure you delete these messages and then recheck to see if they come back so that they aren't a dormant stored code from a while ago.
c3nturi0n
Post by c3nturi0n » Tue Aug 27, 2019 11:45 am
cheers Ian.
Are they known to go faulty or could this be an intermittent one?
e.g. it does come up pretty much every time i run the scan at two/three week intervals.
- H&R ARBs
Users browsing this forum: Google Adsense [Bot] and 26 guests
