SOLD — RS4 B7 Saloon Phantom Black RS04 RAW - MRC Stage 2
jonnyp
Post by jonnyp » Mon Jul 22, 2019 12:29 am
2006 (56) Phantom black saloon
74,100 miles with Full Audi/MRC service history
A well documented example know by many on this forum with a great factory spec and some modifications which only add to the experience
Spec:
Black silk nappa Leather
Heated bucket seats
Front centre armrest
Flat bottomed RS4 steering wheel
Carbon fibre interior trim
Solar sunroof
Bluetooth
Bose sound upgrade
Adaptive xenon headlights (cornering whilst steering)
Clear front indicator lens
Front fog lights
Auto dimming rear view mirror
Light and Rain Sensor
Climate Control
Factory fitted Electric rear blind
Factory fitted Rear window blinds
ISOFIX rear seats
Cruise control
Power assisted steering
Remote Central Locking
Front and rear parking sensors
Electric heated door mirrors
ABS
Electronic Stability Program
Modifications:
Ported, polished & cleaned inlet manifold
Milltek straight through non res/non valved exhaust system from headers back
- OEM Cats available if required
MRC Cold Air Feed
Tarox front discs, ferrodo ds2500 pads
OEM brembo pads and OEM discs on rear
Stainless Steel brake lines with RBF600 fluid
KW v3 Coilovers
H&R anti rollbars
JHM LWFW + OEM clutch
JHM Short Shifter
JHM Intake Spacers
MRC Stage2 custom remap (445ps / 465nm)
Led number plate lights
RS Logo puddle lights
3G RNS-E Retrofit
- Audi Music Interface (USB, 500GB Hard drive, Bluetooth Streaming)
- Higher definition screen
- Faster user interface
- Voice control button added to dash
Security:
Clifford G5 alarm and immobiliser with blackjax
Service history:
(All paperwork dating back to original owner is recorded and retained)
Date. Odometer Garage Cat Scope
07/01/2008 11,006 Audi Service Oil, pollenFilter
23/09/2008 16,256 Audi Service Brake Fluid
27/03/2009 19,106 MRC Service Oil, AirFilter, spark plugs, pollen filter, Carbon clean
15/06/2009 22,560 MRC Service Oil Service
10/09/2009 23,735 MOT MOT
06/02/2010 28,481 MRC Service Oil, BrakeFluid, Carbon Clean
29/06/2010 33,783 MRC Service 10k Service, Oil, Clutch
31/08/2010 38,028 MOT MOT
14/09/2010 38,782 JJB Service Oil
09/03/2011 41,358 MRC Service Oil, SparkPlugs, BrakeFluid, CarbonClean, FuelFilter
06/09/2011 45,370 MOT MOT
18/04/2012 49,377 MRC Service Oil, Pollen Filter, 10k Service
30/08/2012 51,634 MOT MOT
03/09/2013 54,999 MOT MOT
02/05/2014 59,718 MRC Service 60K service, Oil, SparkPlugs, AitrFiltr, Pollen Filter, FuelFilter, gearbox and diff oil replaced
28/08/2014 62,144 MOT MOT
16/02/2015 64,242 ClayMotors Service Oil Service
16/03/2015 64,522 KwikFit Service Aircon recharged
05/09/2015 65,827 MOT MOT
16/11/2015 66,147 Audi Service Oil, BrakeFluid
16/08/2016 67,344 MOT MOT
28/11/2016 67,800 DirectAutoRepairs Service Clutch Kit, Slave Cylinder, Master Cylinder
20/09/2017 68,811 MOT MOT
20/09/2017 68,811 Direct Motors Service Oil Service
22/08/2018 70,089 MRC Service 10k service, Oil, Air Filter, Pollen Filter, Carbon Clean, Lambda Sensor 2
04/10/2018 70,458 MOT MOT
Condition:
Bodywork - Free of dents and dings across all panels. No major scratches and the occasional wash related marring could be detailed out. The lower front end and forward facing arch does show stone related marking which is to be expected of its mileage and more obvious on black paint. There is small under paint bubble on the edge of the front arch where it meets the arch liner. Chrome trim on rear boot entry and front end were recently replaced (58k and 64k) and only the trim around the doors shows slight milking common on the B7
Wheels - Refurbed 3 years ago and have no kerbing related marks. There are a few stone chops and some minor under surface corrosion showing
Tyres - Goodyear Eagle F1 275’s which have been recently rotated so now with (v. approx) 6mm front and 5mm rear even wear across the tyre and no cuts or bulges
Brakes - Recent caliper refurb (Aug 2018 / 69k) and remain in great condition. Pads are at around 80% rear and 70% front. Discs will need replacing with the next set of pads
Suspension - I recently (68k) raised the ride height of the KW v3 coilovers as I wasn’t keen on the arch overlapping the wheel as set by the previous owner and along with this a 4 wheel alignment and health check was completed with no issues to report
Interior - I’d say after seeing quite a few others the interior is in the top 5% in terms of condition. Wear levels on the leather are very low and bolsters are not deformed or showing wear. No interior parts are broken or scratched. In 2015 @ 60k the lower steering trim replacement means the most common wear item is as new. Comes with 3 sets of mats (show/daily/winter). Recent repair to the armrest clip and glovebox damper means all the usual known weak points on the interior have been addressed
Electrical - I have recently corrected a simple wiring issue with the radio which caused it to not illuminate with the headlights and not show in the DIS which was the only electrical issue I found. It starts single press on the start button without delay on a cold start so all relays and related switch gear are good. Bluetooh works perfectly with my iPhone 8 for both calls and music streaming
Its been a joy to get the chance to drive a car of this spec as each of the modifications add a real edge to the car over my previous sprint blue avant which was mainly stock. The exhaust is perfect and my initial fears of it being overly loud were dispelled on the first journey and the mechanical feel of the shifter being spot on with the extra weight the jhm kit adds. Throttle response and torque remind just how good this engine can be and backed up with the brake line and pad upgrades the braking system matches the engines pace with great feel and assurance . This is how I want my next B7 to be only avant form again, sad to think Audi won’t produce a car like this again. This hit home the day I let my son start the car and the look on his face made me realise the cars of his generation might not evoke the same emotions at startup :cry:
Huge respect has to go out to the previous owners as it wouldn’t have been in this condition after this time without some serious care and attention.
Let me know if there are any other details that are needed or any general questions on the car. I'm based in Glasgow, Scotland and can happily do a FaceTime/WhatsApp video call for those further afield to show you around the car.
Asking price is £16495 ono
Andyevo
Re: RS4 B7 Saloon Phantom Black RS04 RAW - MRC Stage 2
Post by Andyevo » Mon Jul 22, 2019 8:49 pm
Awesome car and what an excellent advert! Very detailed.
GLWS
jonnyp
Post by jonnyp » Tue Jul 23, 2019 2:48 am
@andyevo - thanks appreciate the feedback
I grabbed some footage tonight and put it up on YouTube for anyone wanting a taster of the sound.
https://youtu.be/B9C4QWAd9MA
jump to 8:08 for the money shot
John
FaisalJ
Post by FaisalJ » Tue Jul 23, 2019 8:13 am
Andyevo wrote:Awesome car and what an excellent advert! Very detailed.
GLWS
What he said! I’ve sent this on to a family member that is starting to consider a B7 - looks a great example!
2007 RS4 B7 Avant
Quango86
Post by Quango86 » Tue Jul 23, 2019 2:48 pm
Seen this car in the flesh you stay next door to my sister. If anyone is looking for one this is the one to have it looks perfect. I bought one the same week wish I'd seen it at the time!
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
SinghB7
Post by SinghB7 » Tue Jul 23, 2019 9:00 pm
Wish I had the money to buy this back. Absolutely regretted selling it.
Audi RS4 B7 Saloon 456ps MRC
Audi S3 8P 310bhp Revo
Audi S4 B5 Saloon 504ps MRC
Audi S4 B5 Saloon 320bhp Revo
Audi A4 B7 TDI Saloon 215bhp R TECH
:kissmyrings:
fairzy
Post by fairzy » Wed Jul 24, 2019 6:22 pm
Great spec, great ad. Someone’s going to get a great car.
Dom81
Post by Dom81 » Wed Jul 24, 2019 10:19 pm
I knew this car back in it’s first ownership, but it was already a really well looked after car, and was trying stuff (under really good ownership) way ahead of anything else. First carbon clean, first catch-can etc. It also had an exhaust that woke the dead...
2007 Daytona RS4 Avant
jonnyp
Post by jonnyp » Thu Jul 25, 2019 1:28 am
Yeah I spotted you down one evening but didn't want to come knocking at the door as your sister already thinks I'm enough of a car weirdo as it is "is he still washing that car" :)
I've accumulated a small collection of bits and pieces which might be of use to you so ring the bell next time your round and you can take anything you need :beerchug:
Come on Harman, you know you want to...... if the roadworks are still on the M6 you'll get 28.6mpg like I did, that has to be an RS4 world record
Thanks fairzy
Its got a great story for sure, thankfully all that provenance has been retained and not shredded "because of data protection" like a dealer would.
I bought a 997 c4s from Peter Vardy and that was their line when I asked to see the paperwork, which told me how much they understood modern classics. Ironically they now have Peter Vardy heritage which I'm sure they will be happy to show all you would expect to see.
Quango86
Post by Quango86 » Thu Jul 25, 2019 8:39 pm
Thanks fairzy
Perfect I'll pop in when I'm down. Might want to teach her how to clean hers!
HarpreetSingh
Post by HarpreetSingh » Fri Jul 26, 2019 3:26 pm
GLWS, Its through Harmans ownership that I was inspired to get one myself! By chance happened to pick one up with an almost identical number (ROW instead of RAW) :biggrin3:
Wont be long before someone snatches this off you!
Lockstock84
Post by Lockstock84 » Fri Jul 26, 2019 3:33 pm
Hi mate, really interested in this. What’s your contact number to discuss the car?
Cheers,
Dan.
jonnyp
Post by jonnyp » Fri Jul 26, 2019 4:29 pm
Thanks Harpreet
Cheers,
Dan.
I've sent you a PM Dan
jonnyp
Post by jonnyp » Thu Aug 01, 2019 3:42 pm
Bump
mustdash
Post by mustdash » Sun Aug 04, 2019 8:15 pm
Seeing this makes me want to get back in a B7....
CURRENT: Montecarlo Blue Alfa Romeo Giulia Quadrifolglio, 2.9ltr bi-turbo, 510bhp
PREVIOUS: Volvo V60 Polestar, build number 149/700 worldwide - 3ltr straight 6 turbo. 350bhp remapped to 400bhp. Only one of 120 in the UK
PREVIOUS: Misano red B7 saloon, stage 2 map to 425bhp, manifold flap delete, KW V3 coilovers.
Users browsing this forum: Google Adsense [Bot] and 57 guests
