Ds2500 pads
Lukes3
Ds2500 pads
Post by Lukes3 » Wed May 01, 2019 9:25 pm
Anyone ever had this happen?
Only done 2000 mile ish.
Pistolpete2543
Re: Ds2500 pads
Post by Pistolpete2543 » Wed May 01, 2019 10:08 pm
Wow that's pretty scary stuff. I reckon Ferodo themselves might be interested to see this, be worth contacting them. You wouldn't have been sold fake Ferodo pads perhaps (have heard this is quite common).
FrazerD
Re: Ds2500 pads
Post by FrazerD » Wed May 01, 2019 10:20 pm
As said above, I would contact Ferodo and see what they say. How did you come across it was missing half?
Cheers :thumbs:
Re: Ds2500 pads
Post by MikeFish » Wed May 01, 2019 10:43 pm
I've never seen that happen before.
pule333
Re: Ds2500 pads
Post by pule333 » Thu May 02, 2019 12:07 am
Told you they were too soft Image
Ok judging by the rust deposit, I can guess the car has been standing for a while? And you most likely overheated them before.
Ds2500 have a tendency to crumble. Similar thing happened to my second set. Basically I was swapping them over for track day use only. After one of the days, took them of, and put them in the box in the garage (until next track day in a month time) when it came to put them back on, they were crumbling like a cookie around the edges and got all puffed up. My theory is, “good”heat cycle and trapped moisture makes them go bad unless they are constantly used. I threw them away and went for ds3000 (still to soft but better)
They need proper bed in period. According to ferodo, you can’t overheat them in the first 100 miles or so. But my theory, trapped moisture corrodes them from inside making the super soft. This is not my pic, buy mine were similar. Image
By the way, this is my first set of ds2500. They were used daily and that’s after 3rd track day. Image
Honestly, if you want amazing stoping power, try carbotec xp10 or 12
RS4 B7 aka Vinnie
Lukes3
Re: Ds2500 pads
Post by Lukes3 » Thu May 02, 2019 9:37 am
I have sent them a message dont know how long it will take for a reply thou. They were brought from a ferodo dealer so would like to say real.
Lukes3
Re: Ds2500 pads
Post by Lukes3 » Thu May 02, 2019 9:40 am
Cheers :thumbs:
I am replacing the front brakes an doing a few things on the car so its been parked up. But just before parking the car up there was a squeal coming from the rear driver side. Had a quick look an saw a groove had a look and found that
Lukes3
Re: Ds2500 pads
Post by Lukes3 » Thu May 02, 2019 9:43 am
The car has got rust spots now because it has been sitting for 3 months but before that i did use it.
Its been to the ring an back and a few meets here like i said 2000 mile ish. An considering these are rear pads i didnt think they should take much of a beating?
pule333
Re: Ds2500 pads
Post by pule333 » Thu May 02, 2019 9:54 am
You be surprised how much the rears have to work on b7 when you drive in anger :)
RS4 B7 aka Vinnie
Lukes3
Re: Ds2500 pads
Post by Lukes3 » Thu May 02, 2019 10:01 am
Where do you get your pads from? Ill been needing a new set lol
Lukes3
Re: Ds2500 pads
Post by Lukes3 » Fri May 03, 2019 5:32 am
Because this looks like its going to take some time to resolve or for ferodo to replace, i was looking at a set of ebc yellow stuff just to keep me going for abit.
I have never had a problem with?
FrazerD
Re: Ds2500 pads
Post by FrazerD » Fri May 03, 2019 7:00 am
I had Brembo Hp2000 pads on my M3 and had no complaints.
Cheers :thumbs:
Pistolpete2543
Re: Ds2500 pads
Post by Pistolpete2543 » Fri May 03, 2019 1:59 pm
I’ve had yellow stuff pads on the rear for years now, no issues.
Fatneck73
Re: Ds2500 pads
Post by Fatneck73 » Fri May 03, 2019 4:11 pm
Pule333 - xp10’s or 12’s...what’s the diff? What would you recommend buddy? I need to order so would appreciate your steer. 😁
pule333
Re: Ds2500 pads
Post by pule333 » Fri May 03, 2019 4:22 pm
Fatneck73 wrote:Pule333 - xp10’s or 12’s...what’s the diff? What would you recommend buddy? I need to order so would appreciate your steer. Image
Xp12 is more aggressive.
I would go for xp10 if I am honest thats what I have and they are absolutely briliant. Very very noisy tho for everyday driving. Luckily takes less than 5min to swap.
Contact Ian on sales@carbotech-europe.com
RS4 B7 aka Vinnie
Users browsing this forum: Majestic-12 [Bot] and 105 guests
