Audi S4 4.2 V8 Quattro 2004 (B6) manual in Goodwood Green
cobraBLACK
Post by cobraBLACK » Fri Apr 19, 2019 10:17 pm
£7995
140,000 miles
I've owned this car for nearly 10 years, in which time I’ve spared no expense in maintaining and improving it to run approximately 400 BHP. It had done 97k mostly motorway miles when I bought it, so I’ve done less than 5k miles per year since then. It’s been looked after by a local independent specialist and serviced every year using Fuchs Pro S 5w-40 oil.
The timing service (including uprated RS4 guides) was done at 135k miles along with a new clutch and flywheel. If you look at a car without the timing service having been done, add at least £4000 to the cost of the purchase as it is mandatory for every B6/B7 S4 at around 100k miles.
There's curbing on most of the wheels, a couple of small scratches and some stone chips in the usual places. I have just had one of the rear doors and quarter panels sprayed to sort out a couple of larger scratches.
I have extensive history under my ownership and I’ve listed a few of the notable features/repairs below. MOT until March 2020.
Modifications
  • Milltek non-resonating cat-back exhaust
  • JHM short-shifter
  • Apikol snub mount
  • RNS-E Mk. 2 retrofit
  • B7 RS4 RARB
  • 034 Density engine mounts
  • Tarox G88 brake discs
  • JHM tune
OEM replacements
  • A/C compressor (120k)
  • Timing service (135k) incl. RS4 guides
  • Clutch and flywheel (135k)
  • Oil check valves and valley pan gasket (135k)
  • PCV valve (135k)
Equipment
  • Full leather Recaro seats, electrically adjustable
  • Carbon fibre trim panels
  • Xenon headlamps
  • Heated, electrically adjusting/folding wing mirrors
  • Dual zone climate control
  • Multi-function display/on-board computer (DIS)
  • RNS-E Mk II satellite navigation with higher resolution screen, higher capacity SD card reader, etc. and 10-speaker Bose system
  • Roof-mounted media player screen
  • Total closure system
  • Airbags front and rear
  • Electronic Stability Programme (ESP)
  • Servotronic power steering
  • 18" RS4 replicas with Goodyear Eagle F1 tyres
Audi S4 Avant (B6, 2004) in Goodwood Green.
Re: Audi S4 4.2 V8 Quattro 2004 (B6) manual in Goodwood Green
Post by Ian_C » Fri Apr 19, 2019 10:55 pm
Mileage? Price?
cobraBLACK
Post by cobraBLACK » Sat Apr 20, 2019 12:11 am
Whoops!. I'll edit
iconic78
Post by iconic78 » Sun Apr 21, 2019 6:30 am
You’ve a load of bullet points but nothing listed???
cobraBLACK
Post by cobraBLACK » Sun Apr 21, 2019 8:09 am
It must be your phone. I can see it on my phone and laptop.
cobraBLACK
Post by cobraBLACK » Sun Apr 21, 2019 8:12 am
marc1
Post by marc1 » Sun Apr 21, 2019 8:55 am
All works for me.
Car looks good. I’ve always much preferred the looks of the B6 S4 to the B7 S4. It lost its aggression with the B7 facelift unfortunately.
Users browsing this forum: RS4AvantB7 and 82 guests
