Brake judder
holsy10
Brake judder
Post by holsy10 » Sun Mar 31, 2019 11:36 pm
Hi folks
Recently started getting brake judder when braking and after a bit of digging around on here came to the conclusion brake discs had warped. When to garage and it would seem as though the discs where lined up properly as the 2 screws had snapped off that lines everything up.
By any chance does anyone know that screw size?
I know it’s counter sunk screw but unsure on size.
iduff
Re: Brake judder
Post by iduff » Mon Apr 01, 2019 5:20 pm
https://audi.7zap.com/en/usa/audi+rs4+q ... 615055/#17
Says for the 380mm rotors the screw is M6 x 16 countersunk. Guessing it's common across rotor sizes.
You might also consider that your judder is uneven deposits on your rotors. One possible inexpensive solution is to do the brake-bedding rigamarole again, you know, the five or so repeated almost-stops from like 80mph, then after letting them cool off, a few more from a lesser speed. This method doesn't always work, but as it's so expensive <sarcasm>, might be worth the vast investment.
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
James1984
Re: Brake judder
Post by James1984 » Mon Apr 01, 2019 6:24 pm
It shouldn’t matter if the screws are present or not once the wheels are mounted
2007 B7 RS4 Saloon, Phantom Black, Forge Oil Cooler Kit, custom home made air feed, H&R Coilovers, H&R anti roll bars, 10mm H&R Spacers, Milltek decat downpipes, Milltek Non Res Valved Exhaust, Reyland Motorsports front & rear discs with Hel braided Hoses, full underbody overhauled inc powdercoated subframes and arms, 034 solid subframe bushes and every joint, arm or bush replaced.
holsy10
Re: Brake judder
Post by holsy10 » Mon Apr 01, 2019 8:38 pm
Iduff
Cheers for the response. My first job was to try bed brakes in again but hasent worked unfortunately. There’s a company near me that rekon they might be able to skin the discs as they’re quite new for only £50. They said they have done a few of RS4’s failing that new discs :(
holsy10
Re: Brake judder
Post by holsy10 » Mon Apr 01, 2019 8:40 pm
James
I was hoping this is the case. Tbh since I have all the brakes & wheels lined up correctly I haven’t checked to see if it had moved. I just thought while Im getting it done might aswell fit new screws.
iduff
Re: Brake judder
Post by iduff » Tue Apr 02, 2019 2:50 pm
holsy, James is correct, the lug bolts do all you need, except when changing wheels. The small screws simply hold the disc hats in the correct place to allow you to get the lug bolts into the holes in the hubs. Good on you to get it all correct, though.
CPO, stock
Former Quattros
James1984
Re: Brake judder
Post by James1984 » Tue Apr 02, 2019 7:21 pm
Screwfix have the screws, £3 for 50
Covkiller
Re: Brake judder
Post by Covkiller » Tue Apr 02, 2019 9:27 pm
This has been done to death. Look it up and read more.
In short disks don't warp.
Clean your disks, clean you callipers, drill your holes out and jet wash the hell out of them.
Then your brakes won't judder.
MrHilario
Re: Brake judder
Post by MrHilario » Wed Apr 03, 2019 8:58 am
This.
I've had judder many times, and it goes away after some cleaning without changing disks or pads.
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
holsy10
Re: Brake judder
Post by holsy10 » Wed Apr 03, 2019 9:58 pm
Cheers for the reply’s. I did look around on here but didn’t find one that answered my question which was about screw size.
Also I’m only going by what a specialist has told me. I’m a car lover but not technically minded and always get a garage todo the work so if someone has told me this is the problem I’m not one to argue. Once I get car back from having the alloys done i will spend the weekend cleaning and jet washing to see if this gets rid of the problem.
iduff
Re: Brake judder
Post by iduff » Wed Apr 03, 2019 11:00 pm
@holsy, see my earlier reply, pretty sure the screws are M6 x 16 countersunk.
CPO, stock
Former Quattros
holsy10
Re: Brake judder
Post by holsy10 » Thu Apr 04, 2019 7:58 am
Yes iduff I see that thank you.
I was just replying to someone who said this has been done to death. The discs problem has yes but I couldn’t find screw size anywhere until you told me cheers bud.
KernowPete
Re: Brake judder
Post by KernowPete » Fri Apr 05, 2019 4:42 pm
As Cov said, discs do not warp. This is a myth, one I even saw recently perpetuated in EVO mag sad to say. Brake judder is actually caused by one of two things, or a combination of both. One is the interface between the disc and the hub not being totally flush and clean and hence the disc not running true. The other more common one is build up of foreign material on the disc face and in the holes, usually transfer of brake pad material caused by riding the brakes when everything is hot. This creates minute high spots on the disc face which, even though only a fraction of a millimetre thick, can produce truly horrible judder.
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
holsy10
Re: Brake judder
Post by holsy10 » Fri Apr 05, 2019 5:51 pm
Thanks for the reply’s guys.
I think wheels off and a good clean up is in order over the holidays.
Covkiller
Re: Brake judder
Post by Covkiller » Mon May 13, 2019 12:23 pm
Any update?
Users browsing this forum: No registered users and 596 guests
