My flappy paddle is stuck in. Any ideas?
Flappy paddle upshift sticking
- adam88binks
Re: Flappy paddle upshift sticking
Probably dirt. Take airbag off and disassembleSonic2505 wrote:My flappy paddle is stuck in. Any ideas?
Sent from my SNE-LX1 using Tapatalk
Jim Haseltine
Cheers fella. Worked a treat.Jim Haseltine wrote:See viewtopic.php?f=47&t=120828
By doing this you have moved the broken piece of plastic only, it will likely jam up again. I had the same issue with my down shift paddle. You have to remove the air bag and take the trim off the steering wheel to actually access the bolt holding the paddle in. Then you can remove the paddle, take the pin out and separate the parts to fully remove the broken bit of plastic.
There is a good guide to this on YouTube one a TT.
