Any final comments prior to non-res Miltek?
Evening all,
Well I’ve had my RS6 for around 3 months and having had a ‘loan’ of a previously modded example with 720bhp and an aftermarket exhaust (assuming Miltek) I’m about to make the jump to a non-resonated Miltek cat back.
The question is, should I be aware of or consider anything before I do?
The last RS6 had a report of a leaking exhaust when it was in at Audi.Is this a common issue or something to be concerned with? I always assumed Miltek was a solid make/brand?
I’ve still got the Audi warranty and just plan on swapping back to the Audi exhaust whenever I have a service or warranty claim coming up (until I extend at which point I’ll likely just declare it).
Cheers to any input.
Edinburgh Based Nardo Grey C7 RS6
Re: Any final comments prior to non-res Miltek?
I am in the exactly same boat as you are but only owned by RS6 for 2 weeks.
I have asked two different Audi garages and they both said you should be okay for warranty claims as its just a catback (the full system may be different).
Have you seen any videos of the C7 RS6 using just the Miltek non-res catback and not the full system?
Current Cars
Audi RS6 C7
R129 500SL
W124 300CE Mosselman Twin Turbo
W210 E55 AMG
W210 E320 CDI
Audi RS6 C7
R129 500SL
W210 E55 AMG
W210 E320 CDI
Leaking exhaust if probably down to clamps not being tight enough and or no exhaust paste used. Either way it's not a big deal.
Most people on here would consider the milltek to be of poor build quality especially when compare to the £7k Akrapovic (not really a fair comparison).
Some people have a knocking noise with the milltek. Mine does but when I can be bothered to grt under the car and tweak the position slitghly I'm sure that will cure it.
But given all the above I'd still highly recommend it.
Before fitting mine I had my front and centre resonators deleted and gave me a near perfect sound for just a few hundred quid. It stayed like that for nearly 3 years before I got bored and found a cheap milltek.
Some people find it too loud too but it sounds like you have heard it already and like it so you know what to expect there.
That’s my hope too, just fearing meeting my match in the ultimate jobsworth Master TechDanM92 wrote: ↑Mon Jan 14, 2019 12:32 pmI am in the exactly same boat as you are but only owned by RS6 for 2 weeks.
Thanks Mike. I’ve never understood how an exhaust made of what they claim to be aviation grade steel can be that bad though - I’m sure it will do the job or certainly not cause me any real grief anyway! The car definitely needs the theatrics and I certainly miss the burble, pops and bangs on demand.MikeFish wrote: ↑Mon Jan 14, 2019 2:27 pmLeaking exhaust if probably down to clamps not being tight enough and or no exhaust paste used. Either way it's not a big deal.
If the car only had 720ps I'd assume it was a cat back only.
- uplandsway
APR are due to release a sports exhaust..just for thought.
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
Poorly built. I had it on then switched to Capristo. Night and Day.
Mazda Eunos 800M, Mazda Tribute 3.0, Toyota Harrier 2.4, Lexus IS250 Deluxe, Audi Q7 3.6, Golf MKV R32, Audi MK2 TT 3.2, BMW X1 xDrive25i, Audi S5 Sportback, MB C63 Estate, Audi RS6
I have one on my RS7 sound amazing. Quiet on a run as well.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Would be good to know the details of your experience with Miltek and also what kind of duration we’re talking before you started to see issues?
Miltek none resonated exhaust only no other even looked for when considering buying, have it for 2 years no problems so far, sounds amazing and brutal. Sometimes exhaust valve flaps stucks or maybe a little rust spraying wd40 helps)
Thanks Tadass. It was fitted today; picked her up and it’s basically indescribable. The most glorious and brutal thing I’ve ever heard. Spoiled without it!
I had a Milltek on my RS4 for 9 years with no issues at all!
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Previous:
Users browsing this forum: Google [Bot] and 22 guests
