Has anyone fitted 034 motorsport arms - upper and lower to there RS .. just looking for a bit of feedback on whether they worth the money ?
Or just replace all bushes in the OE arms instead.
034 Motorsport
Re: 034 Motorsport
I had the adjustable arms. I was happy with them but they were a pain to adjust as the adjustment came by turning the end connection. This means you have to disconnect one end of the arm every time you want to make an adjustment. So setting them up in the first place takes a bit of time but once set up they are all good.
The Stern adjustable arms allow adjustment in situ so much easier to adjust.
Re: 034 Motorsport
Thanks for your feed back mike..
Basically being on air i want to sort some of my tired bushings and wondering whether new arms as well might be worth it will im at it .
got any advice with ARB's ?
Re: 034 Motorsport
Ah Tommo, thought that was you but wasn't sure.
The adjustable arms should sort out the wear on the inner edges at your normal ride height but not sure how much negative camber you still need to stop it rubbing. Depends on how much you are tucking at normal height and what wheels / spacers. You are running.
The normal arbs do a good job with DRC especially the thicker SS+ one. When people change to coilovers they often change one or both to help control the roll. I just changed my SS one to a SS+ one as I had DRC with KW adjustable springs and it worked quite well.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 438 guests
