Winter tyres
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Winter tyres
Post by c3nturi0n » Mon Nov 19, 2018 4:51 pm
hi guys,
i'm contemplating on an idea to take my RS to the Alps during Christmas break... one really qq re tyres. Would it be worth going for 275 40/20's instead of original 35 fitment for "extra" comfort?
Assume this is / will be safe to use on Quattro so long as all 4 x tyres are of same height?
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Jim Haseltine
Re: Winter tyres
Post by Jim Haseltine » Tue Nov 20, 2018 9:45 am
275/35 = 96 (approx). 275/40 = 110, so the tyre wall will be approx 14mm higher (depending on make and model as all tyre sections are nominal measurements).
You could well get some rubbing at the back especially when loaded and at the front on full lock.
c3nturi0n
Re: Winter tyres
Post by c3nturi0n » Thu Nov 22, 2018 3:38 pm
cheers Jim.
- H&R ARBs
Jim Haseltine
Re: Winter tyres
Post by Jim Haseltine » Fri Nov 23, 2018 10:14 am
And it should go without saying (but I will) the speedo will under read by about 4%.
c3nturi0n
Re: Winter tyres
Post by c3nturi0n » Fri Nov 23, 2018 12:19 pm
hahah :)... that's a nice one.
reason why i'm asking is that 35 profile are tad challenging to source at acceptable prices and I have a hard time convincing myself to spend a "grand+" on something I'd only use for single trip to the Alps. Hence the ask for 40 profile that are somewhat more cost-effective (but with caveats that you outlined Jim).
- H&R ARBs
Doug_RS6
Re: Winter tyres
Post by Doug_RS6 » Sat Nov 24, 2018 2:50 am
Could try a 265/40
c3nturi0n
Re: Winter tyres
Post by c3nturi0n » Sat Nov 24, 2018 5:31 pm
thanks Doug.
Wonder if anyone tried 265/40 20's and how do they fit to a car?
- H&R ARBs
Jim Haseltine
Re: Winter tyres
Post by Jim Haseltine » Sat Nov 24, 2018 6:46 pm
Dunno, but I'll tell you this, once you've driven with winter tyres you'll want to fit them in this country when the temperature drops. The grip is amazing compared to summer or all weather tyres. There are downsides though, they don't last long when things get warmer and they're usually rather noisy on dry roads.
HPsauce
Re: Winter tyres
Post by HPsauce » Sat Nov 24, 2018 7:00 pm
I've probably said this before, but I find the best method is to have a second set of wheels with winter tyres fitted.
Smaller diameter (assuming the car brake geometry allows this) with deeper tyres to maintain the same rolling radius.
c3nturi0n
Re: Winter tyres
Post by c3nturi0n » Sun Nov 25, 2018 8:26 pm
HPsauce wrote:I've probably said this before, but I find the best method is to have a second set of wheels with winter tyres fitted.
Not much other than std would fit RS tbh... hence the ask to see what options if any are out there.
- H&R ARBs
Doug_RS6
Re: Winter tyres
Post by Doug_RS6 » Sun Nov 25, 2018 9:31 pm
thanks Doug.
By reducing the width you reduce the radius too as the 40 is a percentage of the width. It will also very slightly pull the sidewalls in giving a little more clearance.
Jim Haseltine
Re: Winter tyres
Post by Jim Haseltine » Mon Nov 26, 2018 11:28 am
265/40 is 106mm - approx 10mm higher than a 275/35 sidewall.
Doug_RS6
Re: Winter tyres
Post by Doug_RS6 » Mon Nov 26, 2018 12:22 pm
You will lose some of that 10mm though as the sides pull in giving a more rounded sidewall.
c3nturi0n
Re: Winter tyres
Post by c3nturi0n » Mon Nov 26, 2018 12:38 pm
Guess car won’t loose much on stability and performance etc.?
- H&R ARBs
Doug_RS6
Re: Winter tyres
Post by Doug_RS6 » Mon Nov 26, 2018 1:54 pm
I wouldn't of thought so. I mean they compound and design of the tyres will be the most obvious change.
Users browsing this forum: Google Adsense [Bot] and 106 guests
