Modifying the RS4
sportsandclassic
Modifying the RS4
Post by sportsandclassic » Sat Nov 10, 2018 6:23 pm
Hi Everyone,
Well had the RS4 for 3.5 years now and other than sports exhaust, gut the pre-cats and a MRC map I have left it pretty standard.
Almost sold it but could not bring myself to do it.
So thought I would customise the car a little....
Suspension is knocking from front quite a lot now - DRC has issues. New Bilstein PSS9 suspension ready to go on the car.
Carbon interior trim set of eBay on the way to replace the satin steel inserts.
Spray wrapping the satin exterior trims to look like black optics pack.
Got a splitter of eBay coming.
Got a new set of BBS CH-R Nurburgring satin black with red edge stripe coming from Germany and a new set of Michelin tyres.
New floor mats and boot liner to finish it off.
Will update with images as the work progresses.
Before any mods
FrazerD
Re: Modifying the RS4
Post by FrazerD » Sat Nov 10, 2018 7:28 pm
Doing the window trim and roof rails black will make a big difference and the new wheels will look a treat. When you say sports exhaust, what do you mean? I’m thinking about gutting my pre cats as I have the resonator delete but not sure if it’s worth the effort. Is the MRC map a stage one or two? And what are your thoughts?
Cheers :thumbs:
sportsandclassic
Post by sportsandclassic » Sat Nov 10, 2018 10:57 pm
Hi, I knocked the pre-cats out when I removed the gearbox to do a clutch and flywheel.
I have a resonated Milltek valved system with stage 2 MRC map.
Mike
coffey555
Post by coffey555 » Sat Nov 10, 2018 11:36 pm
I think the car looks pretty good as it is to be honest but if you fancy a change then why not. Should be easy to put it back to standard again in the future if needed.
Picking up a second set of standard wheels in black next month, curious to see how they will look against the silver trim and mirrors.
Not that many red Avant's about so looking forward to seeing how your one looks with the mods.
Misano Red RS4 B7 Avant
FrazerD
Post by FrazerD » Sat Nov 10, 2018 11:52 pm
Mike
Did you notice a difference in sound when you gutted the cats? What were your thoughts on the stage 2?
Cheers :thumbs:
sportsandclassic
Post by sportsandclassic » Sun Nov 11, 2018 9:54 am
Mike
Cheers :thumbs:
Hi, I noticed a bit more of crackling and popping without the pre-cats installed. The map is good but when cold they are quite jerky and kangaroo a bit unit warmed through. I know the secondary air injection system is disabled to enable this quite start but it’s still quite loud, once mine is all done I am going to book back in with MRC and see if they can possible tweak the cold / warm up fuel mixture tables and richness it up a little as to me it seems a little lean when cold but we will see.
Other than that it goes really well.
Like I say I looked at selling it and did sell but pulled the deal the day before as I could not part with it.
Mine has had a lot of work -
Carbon clean
New fuel pumps
Full service
Ignition coils
Clutch
Flywheel
Slave cylinder with piping
Tyres
Brake discs and pads all round
A bit of suspension work
Wheel alignment
Auxiliary radiator
sportsandclassic
Post by sportsandclassic » Sat Nov 17, 2018 8:20 pm
Well, fitted the carbon interior I bought off eBay. What a difference that has made. Very pleasant.
Also fitted the front splitter today.
marc1
Post by marc1 » Sun Nov 18, 2018 11:55 am
That splitter looks good mate. Look forward to more pictures as you continue modding the car.
Post by MikeFish » Sun Nov 18, 2018 12:27 pm
The splitter looks good but looks unpainted. I'd have it painted either gloss black but then it wouldn't match the alu trim. So I'd go for black optics.
FrazerD
Post by FrazerD » Sun Nov 18, 2018 5:55 pm
Looks good, I’m looking forward to seeing the trim and new wheels.
Cheers :thumbs:
sportsandclassic
Post by sportsandclassic » Wed Nov 21, 2018 4:34 pm
New BBS wheels and Michelin Tyres arrived.
FrazerD
Post by FrazerD » Wed Nov 21, 2018 5:07 pm
Good stuff, when they going on? Have you got spacers already or putting some on?
Cheers :thumbs:
sportsandclassic
Post by sportsandclassic » Wed Nov 21, 2018 5:25 pm
Spacers on rear already. Just need some time to put the suspension on. Probably mid December before I get chance!
FrazerD
Post by FrazerD » Wed Nov 21, 2018 7:24 pm
Looking forward to seeing it.
Cheers :thumbs:
sportsandclassic
Post by sportsandclassic » Thu Nov 22, 2018 11:06 pm
Roof bars removed now.
Mirrors and base plates removed.
All ready for painting and spray wrapping.
Going to paint the mirror bases satin black and mirror covering a gloss black.
All other trims are going gloss black.
Should be done for next Friday. Image
Users browsing this forum: Google Adsense [Bot] and 103 guests
