Tin worm
12th
Tin worm
Post by 12th » Wed Nov 07, 2018 2:00 pm
I've had a tiny bit of corrosion on the front driver's side wheelarch, just above the side valance at the rear of the wheel. Seemingly successfully treated, but looks as though it's bubbling just the tiniest amount again. A known issue? Any comments?
Cheers.
Simon
Jon_J
Re: Tin worm
Post by Jon_J » Wed Nov 07, 2018 5:47 pm
12th wrote:I've had a tiny bit of corrosion on the front driver's side wheelarch, just above the side valance at the rear of the wheel. Seemingly successfully treated, but looks as though it's bubbling just the tiniest amount again. A known issue? Any comments?
Cheers.
Simon
Ring Audi UK they will repair under warranty with a contribution from you provided it hasn’t been repaired at some point.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
12th
Re: Tin worm
Post by 12th » Thu Nov 08, 2018 9:53 am
I might do that. It has been treated externally (i.e. repainted to a very high standard) but the car hasn't been damaged if that's what you mean.
coffey555
Re: Tin worm
Post by coffey555 » Thu Nov 08, 2018 10:56 am
The arch liners rub the paint away on the inside of the arches and water and dirt works its way under the paint, causing the bubble you are seeing.
Audi replaced both my front wings under the 12 year paint work warranty because both wing were original paint.
The rear arches did the same a year later but Audi refused to cover the left rear because it had been painted at some point.
The actually got their own paintwork specialist in to measure the paint thickness on that side of the car.
So, if you have had paintwork done, Audi are unlikely to consider a warranty claim. The dealership makes a difference as well, Edinburgh Audi could not have cared less but Perth Audi went out of their way to push the claim through for me.
Probably a good idea to get the inside of all the arches checked along with the rear subframe for corrosion if you are planning on keeping the car longterm.
Misano Red RS4 B7 Avant
12th
Re: Tin worm
Post by 12th » Thu Nov 08, 2018 11:02 am
OK, thanks for that. The paintwork was just a very minor touch-up and done in the last few months, so I reckon a claim is worth a go. Twelve years is up in January! Might help that I am the original owner, and I do intend to keep it.
Cheers.
Jon_J
Re: Tin worm
Post by Jon_J » Thu Nov 08, 2018 6:03 pm
12th wrote:OK, thanks for that. The paintwork was just a very minor touch-up and done in the last few months, so I reckon a claim is worth a go. Twelve years is up in January! Might help that I am the original owner, and I do intend to keep it.
Cheers.
Just to be clear there is no 12 year paint warranty. It’s three years and if it has been painted by anyone other than Audi it is void. The 12 years people refer to is body panels but...that actually (when you read it) refers to internal seams not anything external.
That’s why they ask for a contribution as they usually agree to do it as a good Will gesture. Be warned, they don’t have to do it all all.
12 year paint and body warranty doesn’t exist in the from people believe it does, it’s very specific.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
mikep99
Re: Tin worm
Post by mikep99 » Thu Nov 08, 2018 7:05 pm
When you say rot? Do you mean rust?
If so, the arches are aluminium so this shouldn't happen.
Be interested to know otherwise.
Mike
Sent from my PRA-LX1 using Tapatalk
coffey555
Re: Tin worm
Post by coffey555 » Thu Nov 08, 2018 9:17 pm
You are correct, the front arches are aluminium alloy but the paint will still bubble and lift when water and dirt gets in.
MB2
Re: Tin worm
Post by MB2 » Thu Nov 08, 2018 9:49 pm
Audi replaced both my wings due to corrosion they specifically mentioned the 12 year perforation warranty so this is what they seem to be using to justify the claims.
Jon_J
Re: Tin worm
Post by Jon_J » Thu Nov 08, 2018 11:10 pm
Absolutely correct, they are using it but it isn’t actually covered. All I’m saying is they can say no if they want as it is not covered.
I have spoken to and even advised several members about how to get this work done so they definitely will do it.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
12th
Re: Tin worm
Post by 12th » Fri Nov 09, 2018 9:17 am
I'm going to ring them shortly and get the car booked in to see what they think. I guess my fear was that the panel itself would be corroding from within, as cars did of yore, but whilst I knew they were aluminium I hadn't figured this out as improbable. Just had a crown fall out too, so need a dentist as well. I'm hoping there's no third thing...
Cheers!
(I would post a pic, but I take it these have to be hosted elsewhere and can't be uploaded to the forum.)
Jon_J
Re: Tin worm
Post by Jon_J » Fri Nov 09, 2018 9:40 am
12th wrote:I'm going to ring them shortly and get the car booked in to see what they think. I guess my fear was that the panel itself would be corroding from within, as cars did of yore, but whilst I knew they were aluminium I hadn't figured this out as improbable. Just had a crown fall out too, so need a dentist as well. I'm hoping there's no third thing...
Cheers!
The aluminium will be corroding and bubbling through the paint.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
12th
Re: Tin worm
Post by 12th » Fri Nov 09, 2018 4:33 pm
Well, booked in so we'll see what we see. I guess I'm reassured that an aluminium panel should be rather less prone than a steel one.
Fingers crossed, eh?
Jon_J
Re: Tin worm
Post by Jon_J » Fri Nov 09, 2018 6:35 pm
12th wrote:Well, booked in so we'll see what we see. I guess I'm reassured that an aluminium panel should be rather less prone than a steel one.
You’ll be fine. Unless it has visible damage or a bad repair before they will more likely offer something.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
12th
Re: Tin worm
Post by 12th » Wed Nov 21, 2018 10:38 am
Dealership took a look and forwarded photos to Audi UK yesterday, so we'll see where we go.
Thanks for the pointers.
Users browsing this forum: No registered users and 95 guests
