2001 B5 RS4 Brillant Black (12 months MOT)
silky16v
Post by silky16v » Sun Sep 09, 2018 11:21 am
Spec:
B5 RS4 2001 (Sept 2001, 51 reg) private plate will be removed
139,000 Miles
HPI clear,
Brilliant Black
Black Leather heated electric seats
Carbon Trim
Standard 18” Hard wheels fitted with Verdestein Ultra Vorti tyres (done 3500 miles)
Front, side & curtain airbags
Cruise control
Electric windows
Climate control
Dash display cluster replaced (no dead pixels)
Electrically adjustable mirrors
Front and rear headrests
Heated windscreen nozzles
Alcantara Clubsport steering wheel and gear knob
Split folding rear seats
Ski hatch through rear seats
Retractable rear load cover
Retractable rear dog net
RS4 floor mats
Xenon headlights
LED lighting & numberplate lights
MK4 Golf rear wiper and motor (faces right instead of left)
Front centre armrest
SatNav and TV RNS-D & 6 disc changer (all fully working)
Full Service History, original wallet, 2 keys (1 bentley type)
Full folder of Genuine receipts and include in excess of 20k spent at MRC alone (whatever it needed it got)
Car is fault free the only error is the analogue TV tuner unit no longer being present in the boot.
12 months MOT 30/09/2019 (CV boot replaced for MOT)
I've replaced/renewed all the common fault parts on the car to make it as perfect and reliable, so that the new owner hasn't got to worry about any major expense in the future.
The car has had the all important expensive items replaced like the Turbos, Camshafts, Tensioners & Chains as well as the clutch, cambelt, waterpump & thermostat (and i believe are a must when looking at B5 RS4's)
I've had the paint work pro detailed to best it can (without attacking it too hard) the paint work does have some marks and stone chips.
The lower intercooler (no fog lights) & centre grill plastics are quite stone chipped and the boot lid has been painted.
The doors and front and rear wings are rust free, the side skirts have the usual light scuff marks where people not been taking car getting in and out as well as the top part of rear bumper as you get in and out of the boot (the car was like this when i bought it).
The wheels are all straight but do have some marks on them and to be perfect would want painted/refurbed.
But please bare in mind it is 17yrs old and has some marks and been used as intended, the car is very presentable and polished up lovely and holds it own against much newer cars.
For looks alone there isn't a better looking Audi Avant than a B5 RS4.
I have owned many previous Audi RS and S cars, I will not entertain stupid PM's or daft offers, negative comments, no swaps or p/x.
Genuine Interested buyer i ask that you call me to talk about the car (will send number via PM) and not send endless messages!
Come view the car before starting any negotiations about price.
Any test drive will be conducted by myself unless proof of Full Comp insurance can be shown and proof of funds to be able to purchase.
The car has 2 price option:
As the spec below £16950 (With Audi Clubsport Suspension)
With Bilstein B16 PSS9 Coilovers (done around 4000 miles) £17950 (currently still fitted on the car)
The car is located in North West Cumbria (around 1 hour from Jct36 of the M6)
Engine Mods:
MRC modified air box with oem filter
MRC Silicone intake pipe
All seals replaced in spider hoses and new one way valve and PCV valve
New seals and silicone sealed charge pipes to throttle body
MRC map LC & FS (made 480ps and 703nm on MRC dyno)
Bosch 044 fuel pump
Genuine engine & gearbox mounts (112,000 miles)
Genuine BW KO4 turbos replaced by MRC (112,000 miles) (car runs and holds a safe 1.5bar)
Exhaust Camshafts replaced by MRC (112,000 miles)
Chains and tensioners replaced by MRC (112,000 miles)
Cambelt, waterpump and thermostat replaced by MRC (112,000 miles) (and again by previous owner 2016 at 131,000 miles)
3” XS power (with flexi's) heat wrapped down pipes mated to Milltek non-res system.
Recently had (2018) new N75 valve, pcv valve, alloy check valve, after-run sensor, coolant temp sensor
bosch lambdas sensors, fuel filter, pollen filter, power steering fluid flush and fluid
all intercooler pipework & intercooler removed and flushed and new jubilee clamps
ICM removed cleaned and re-seated with new thermo paste
engine serviced using genuine oils, gearbox and rear diff oil replaced
Cam cover gaskets and cam seals all replaced (camshaft inspected July 2018)
Full alignment all adjustment bolts removed and cleaned and copper grease applied
Full front end arm kit HD Meyle including bolts
Deuter Motorsport polybushed 75ShA upper rear A-arms
DS2500 front pads and Ferodo premier rear pads
July 2018 the car was given a health check and some minor work at Jimbo's in N.Yorks
(anyone who knows B5 RS4's will know of Jimbo and his vast knowledge of these vehicles)
power steering fluid flush and fluid replacement,
refit front driveshaft heat shields & subframe brace,
leak test and slight leak fixed in lobster claw hose,
fit diverter valves right way around,
rear diff replaced due to leaking input (expensive fix) & output seal (this was with a lower mileage RS4 diff),
general checkover and given the all clear
Brakes:
TTRS 4-Pot Brembo Calipers with new discs
Ferodo DS2500 front pads
New rear discs (not sure what type Jimbo seems to think Phaeton) and Ferodo pads all calipers cleaned and serviced slider re-greased
Braided lines front lines
Genuine fluid flushed July 2018
Suspension:
Audi Clubsport Suspension Kit
Rear 034 Motorsport anti roll bar with alloy strengthening brackets
Complete set of Meyle HD front arms and bolts
Deuter Motorsport rear upper A-Arm 75ShA (red bush) May 2018
all other rear bushes in perfect used condition
adjustment bolts removed cleaned and regreased
Full alignment June 2018
Drive train:
Single mass flywheel and Genuine RS4 clutch (can be noisy at very low rpm in higher gears)
Gearbox and Diff fluids all changed, new Genuine RS4 shifter mechanism.
ICE:
Genuine RNS-D satnav and TV with 6 disc changer
Front door speakers replaced with Infinity reference items.
Rear Bose speakers
#VAGDoctor
RS620
Re: 2001 B5 RS4 Brillant Black
Post by RS620 » Sun Sep 09, 2018 7:22 pm
Really nice looking example, GLWS!
silky16v
Re: 2001 B5 RS4 Brillant Black (Revised Price)
Post by silky16v » Tue Sep 25, 2018 9:23 am
Revised Price £16950
Bilstein B16 removed and Audi Clubsport Suspension Kit fitted
Will also be putting the car in for MOT this week
#VAGDoctor
Post by chunky79 » Tue Sep 25, 2018 11:10 am
Nice car, really like it.
RS4LAD
Post by RS4LAD » Tue Sep 25, 2018 1:04 pm
If this is Robs car, I can vouch for how clean and mechanically sound this car is as I have seen it myself at MRC Tuning. ZERO EXPENSE SPARED.
silky16v
Re: 2001 B5 RS4 Brillant Black (12 months MOT)
Post by silky16v » Mon Oct 01, 2018 8:14 pm
12 months MOT on the car now :thumbs:
#VAGDoctor
silky16v
Post by silky16v » Mon Oct 15, 2018 12:10 pm
Advert updated
#VAGDoctor
Users browsing this forum: No registered users and 315 guests
