Morning ,
These are the ones far R/L of the lower bumper I think they are for disc cooling but may be just blanked off behind the small honeycomb section .
Anyway a wood pigeon with a death wish flew straight in front of the car and dislodged the small grill, with a little fiddling it's all back in place fine , but I can see the plastic blank or channel behind had moved back maybe a few mm and the clips are showing . Could someone tell me the best way to access this to pull back flush? Was thinking access in the wheel arch should be directly behind, I've not managed to find a diagram online .
A
Lower side vents
Lower side vents
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
Re: Lower side vents
I'll answer my own here as it's unknown .
Access is gained via wheel off removing guards and you in there to reseat .
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
Users browsing this forum: Bing [Bot] and 48 guests
