Fault code help
Fault code help
Came to start the car Saturday morning and just didn’t sound right and the pedal moved but the engine didn’t register the pedal movement so got the car code read and I’ve got the follow diagnostic
Control module malfunction- DBW throttle monitoring
P1388 - 008 intermittent
I’ve done some digging on line but not really coming up with any soloutions. Don’t really fancy starting buying parts for the sake of it
If anyone can help it would be greatly appreciated
Re: Fault code help
Whereabouts are you?
Someone nearby might be able to help out.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
Re: Fault code help
What code reader was used? If you have a specific code from it you could probably narrow it down to the pedal sensor or throttle body.
VCDS scan should give you that detail and enable you to monitor movements of pedal sensors and throttle body.
As noted above an adaptation would be a good initial step; can that be done on this model without diagnostics tools connected?
Re: Fault code help
I don't think it can be done without a diagnostics tool being connected. On ElsaWin it states that if renewing a throttle valve module, then an adaptation must be performed using VAS 5051.
VCDS is a very good tool and well worth the money. For the price of the 3 VIN version of VCDS, you'd probably not even be able to get any garage to perform an adaptation on your throttle valve modules, let alone take logs of the position sensors for the throttle valve modules and pedal sensor.
Re: Fault code help
VCDS can do this looking at the label file for the engine 1 ECU and engine 2 ECU attached, but I've not tried this personally
It comes under blocks 060 onwards extract below, taken from 07L-910-552-BUH1.lbl
060,0,Electronic Throttle (Throttle Body Alignment)
060,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %
060,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %
060,3,Throttle Valve,Steps Counter,Range: 0...8\nSpecification: 8
060,4,Throttle Body,Alignment Status,Range: ADP RUN/ADP. O.K./ADP ERROR\nSpecification: ADP. O.K.
B060,0,Throttle Body Alignment
B060,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %
B060,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %
B060,3,Throttle Adaptation,Steps Counter,Range: 0...8\nSpecification: 8
B060,4,Throttle Body,Alignment Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
B060,11,Prerequisites: Ignition ON & Engine OFF
B060,12,The Throttle Body Alignment is completed when Field 4 shows "ADP OK".
061,0,Electronic Throttle
061,1,Engine Speed,(G28),Range: 0...6700 RPM\nSpecification (Idle): ~650 RPM
061,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
061,3,Throttle Valve Angle,,Range: 0.0...100.0 %
061,4,Operating,Condition,x0xxx? = A/C Compressor\nx0xx?x = Gear engaged\nx0x?xx = A/C Readiness\nx0?xxx = Rear Window Heater\n?0xxxx = Front Window Heater
062,0,Electronic Throttle (Sensor Values)
062,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %
062,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %
062,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %\nSpecification: 12.0...97.0 %
062,4,Accel. Pedal Pos.,Sensor 2 (G185),Range: 0.0...100.0 %\nSpecification: 4.0...49.0 %
063,0,Electronic Throttle (Kick-Down Alignment)
063,1,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %\nSpecification: 12.0...97.0 %\nSpecification (Kick-Down): 79.0...94.0 %
063,2,Kick-Down,Alignment Value,Range: 0.0...100.0 %\nSpecification: 79.0...94.0 %
063,3,Kick-Down,Switch,Range: Kick Down
063,4,Kick-Down,Alignment Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
B063,0,Kick-Down Alignment (Automatic Transmission only)
B063,1,Throttle Position,Sensor (G79),Range: 0.0...100.0 %\nSpecification: 12.0...97.0 %\nSpecification (Kick-Down): 79.0...94.0 %
B063,2,Kick-Down,Alignment Value,Range: 0.0...100.0 %\nSpecification: 79.0...94.0 %
B063,3,Kick-Down,Switch,Range: Kick Down
B063,4,Kick-Down,Alignment Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
B063,11,Prerequisites: Ignition ON & Engine OFF
B063,12,Press the Accelerator Pedal down to the floor.
B063,13,Wait until Field 4 shows "ADP OK".
064,0,Electronic Throttle (Sensor Adaption Values)
064,1,Lower Adaptation,Sensor 1 (G187),Specification: 0.4...0.6 V
064,2,Lower Adaptation,Sensor 2 (G188),Specification: 4.0...5.0 V
064,3,Emergency Air Gap,Sensor 1 (G187),Specification: 0.5...1.0 V
064,4,Emergency Air Gap,Sensor 2 (G188),Specification: 4.0...5.0 V
It comes under blocks 062 onwards extract below, taken from 07L-910-552-BUH2.lbl
060,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %\nSpecification (Idle): XX.0...XX.0 %
060,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %\nSpecification (Idle): XX.0...XX.0 %
B060,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %\nSpecification (Idle): XX.0...XX.0 %
B060,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %\nSpecification (Idle): XX.0...XX.0 %
Always worth exploring those label files
Re: Fault code help
I've done it on older FBW engines and IIRC block 62 shows both the pedal and throttle body readings, with expected ranges.
They both have dual sensors that work in opposite directions.
IIRC there's a button to click on in VCDS to do the adaptation for you, with explanatory text.
I played with all this years ago when I was having some weird power-fluctuation problems; turned out in the end to be due to a maladjusted brake pedal switch operating on a hair trigger!
Re: Fault code help
Here is a link to a video explaining how to carry out the throttle valve module adaptation on YouTube by Ross Tech.
They have lots of videos that help with using VCDS.
https://youtu.be/2zrmhDw_v7Y
Users browsing this forum: Google Adsense [Bot] and 57 guests
