My RS4 sits wonky??
4.2 V8 32v FSI - 444 bhp
Scottyr81
My RS4 sits wonky??
Post by Scottyr81 » Fri Jun 29, 2018 2:56 pm
Have owned the car for a couple of months now and to be honest I have never looked at the arch to wheel gap in much detail but I have noticed that the passenger side sits probably 20mm higher than the drivers side. From googling I have come up with the answer that when the car is started and driven it levels itself up etc?? Is this the case??? If the reason is bad then please don't tell me, click the back tab on your browser and say no more about the situation.........
Madelvic
Re: My RS4 sits wonky??
Post by Madelvic » Fri Jun 29, 2018 3:59 pm
Noticed that about mine but it doesn’t sit on a level surface at my house. Will check in the company car park today
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Golf GTi Mk 1, Mk 2, Mk 3, Mk 4, VR6,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
PA_RS4
Post by PA_RS4 » Fri Jun 29, 2018 5:43 pm
Following, as I sometimes noticed this about mine...but driveway is sloping too and put it down the DRC suspension and due to it not sitting on a level drive. Only had it about 10 weeks, but noticed it once or twice...
Current: RS4 B8 Panther Black
Audi E-tron (daily driver)
Previous:
BMW X3 330 MSport, Carbon Black
Porsche 911 997 C2S Manual, Basalt Black
BMW 330d Manual MSport Convertible
Madelvic
Post by Madelvic » Fri Jun 29, 2018 5:55 pm
Hard to measure but my car is slightly up at the offside rear. Maybe by 1 cm? Front nearside/offside seems level
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Sammyb349
Post by Sammyb349 » Fri Jun 29, 2018 9:34 pm
There is a huge thread on uneven ride height - it was brought up in connection with DRC troubles
Current:
- Audi B8 RS4 - Panther Black
Previous:
Shockerboy
Trader (Expired)
Post by Shockerboy » Mon Sep 10, 2018 10:28 pm
Before panic sets in , open the drivers window push the top of the door / roof vigerously side to side and slowly come to a rest ( on an even FLAT surface ) , check gaps from centre of Wheel only, to top of the arch ( apex ) . anything more than 10 mm could be an issue , the agents would say normal up to 12 mm . remember shocks are there to resist movement so generally all cars sit lower on drivers side after driver has got out of the car the shock is trying to hold that side from moving back up . It will move up to apoint but 9 times from 10 it will hold lower .
innercry666
Post by innercry666 » Tue Sep 11, 2018 9:30 am
I hate to give the stock Audi answer but, "they all do that sir!". Everyone I have seen seems to sit lower at the rear right. I had the front shocks replaced on mine and it did exactly the same before and after. Before selling my next step was to fit adjustable KW springs to see if it could be dialled out.
As they all do it, it may well be a characteristic of the DRC system itself. It never seemed to cause an issue.
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
Focus ST170 - Garaged
Covkiller
Post by Covkiller » Tue Sep 11, 2018 1:04 pm
All standard cars sit uneven 10mm is nothing to worry about as the weight of your car varies above each wheel. If you want all heights equal you need to fit coilovers and have your car professionally corner weighted.
MK2Golf24v
Post by MK2Golf24v » Tue Sep 11, 2018 1:51 pm
You're contradicting yourself there, if you want all corner weights equal - the heights vary, if you want all heights equal - the corner weights vary.
Covkiller
Post by Covkiller » Tue Sep 11, 2018 8:13 pm
Corner weighted is a process term and as part of the process each corner of the cars suspension height is adjusted so that the they are equal ie fronts equal and rears equal eg my E36 M3 I had done recently, refer to Yellow speed heights:
johnnydog
Post by johnnydog » Thu Sep 13, 2018 10:32 pm
With the earlier issues surrounding knocking or leaking front shockers with DRC, some owners were reporting that when the new shockers had been fitted, the ride height on the side of the replacement shocker was different to the opposite side. You wouldn't have thought it would alter the ride height side to side if a pair had been replaced; maybe it was if just one corner had been replaced.
Your local Audi dealer should be able to go into your cars history and tell you if any warranty work with the suspension has been done on the car and exactly what was replaced.
MK2Golf24v
Post by MK2Golf24v » Fri Sep 14, 2018 3:02 pm
Mine has always had a slight difference left to right at the rear, usually rear pas side higher. Ranges from 5-25mm depending how its parked. Some time its even....
Just put KW springs on it, have kept the lowering the same each side, so still have the slight mis-match. just had the DRC pressures checked at Audi, 20bar both systems, so all good there.
I suspect its the relatively thin ARB not transferring a lot of load across the axle when static, and letting the DRC do the work while the car is in motion.
spoonz
Post by spoonz » Wed Mar 31, 2021 5:23 pm
Thread resurrection!
Just had a rear DRC pipe replaced and system refilled and re-pressurised.
Noticed today that when sat the rear drivers side is sat lower, prob about 10mm from wheel, others are 20mm perhaps. Not measured.
I am guessing this is "they all do that" territory? Any one got a link to the longer thread?
Rugslasher
Post by Rugslasher » Wed Mar 31, 2021 7:52 pm
Mine did the same ........ until I ripped the DRC off 😂 that’s one thing about adjustable coil overs you can tweek em
spoonz
Post by spoonz » Wed Mar 31, 2021 8:08 pm
Phew. It looks fairly <beep>, but given its had the best part of £3k spent on DRC in the last 12 months, Im glad its not another pending visit from Mr B.Bills. :audibash:
Users browsing this forum: No registered users and 61 guests
