Car won’t boost more than 5 psi, boost leak?
Post by 8520 » Tue May 29, 2018 9:26 pm
Scanned with Vag Com, no codes but the car won’t boost past 5 psi. Requested boost versus actual boost is way off.
Do I have a boost leak somewhere? I’ve already checked intercooler hoses and swapped the n75 out with a spare.
Car is 034 chipped and I have Wagner ic’s.
03 RS6 sedan V8TT, 03 S6 Avant V8, 06 Touareg V8, 03 Silverado V8
All V8’s in my garage because America :mrgreen:
Re: Car won’t boost more than 5 psi, boost leak?
Post by Shoppinit » Tue May 29, 2018 10:38 pm
What are your MAFs reading?
And your trim values?
Pull your DVs off and test them (suck test).
Post by 8520 » Tue May 29, 2018 10:51 pm
Shoppinit wrote:What are your MAFs reading?
Had already swapped dv’s. Forgot to mention that.
I’ll try to get those other readings tonight.
paulyang39
Post by paulyang39 » Wed May 30, 2018 3:44 am
Recently i just check my Intercooler and noticed the oil at the edge on both of my intercooler,
and i pressure test them, they are absolutely leaking~~
since this is very easy to check, you can check this area too when you got time.
Post by bam_bam » Wed May 30, 2018 8:58 am
Pull your DVs off and test them...
Isn't this a wank test?
MeTsU
Post by MeTsU » Wed May 30, 2018 9:38 am
I'm not familiar with this method - would you mind explaining in great detail?
2004 Audi RS6 Avant Plus #283
Post by bam_bam » Wed May 30, 2018 10:49 am
Well... when you suck your DV off it's a blowjob. When you pull your DV off, it's the wank test.
MeTsU
Post by MeTsU » Wed May 30, 2018 11:47 am
Ah, sounds like one could really enjoy this. I'll have to give it a go.
Post by Shoppinit » Sat Jun 02, 2018 11:14 pm
You make any progress on this?
Post by 8520 » Wed Jun 06, 2018 5:17 pm
Shoppinit wrote:You make any progress on this?
Sorry, but no. Suspension issues were a bit more pressing due to bad drc and upper control arms. Got in to that last night, and needless to say I will never buy a car that isn’t from the west coast again. Frozen pinch bolts on both sides.
Post by Shoppinit » Wed Jun 06, 2018 5:25 pm
Wish they all could be Californian, eh?
Post by 8520 » Wed Jun 06, 2018 10:16 pm
Shoppinit wrote:Wish they all could be Californian, eh?
I live near Seattle so I’m not used to dealing with corrosion at all Image
Post by 8520 » Mon Jun 11, 2018 5:00 pm
Success.
Mɐʇʇ
Post by Mɐʇʇ » Mon Jun 11, 2018 5:54 pm
Nicknamed the bastard bolt for a good reason.
PipRS6
Post by PipRS6 » Wed Jun 13, 2018 11:24 am
Every car has a bolt that takes on the name of bastard bolt.
Users browsing this forum: Majestic-12 [Bot] and 68 guests
