Wanted : B5 (2001) RS4 Front mounted oil cooler
weta.worker
Post by weta.worker » Tue May 01, 2018 6:42 am
Hiya, I'm after a replacement front mounted oil cooler for my B5 RS4.
I'm just on the tail end of an engine and gearbox rebuild and the mechanics have found that my oil cooler is missing some thread...
Does anyone have any leads on a replacement unit (2nd hand is fine if in great condition)
John (Wellington, New Zealand)
2001 RS4 NOGARO BLUE
1994 RS2 GUARDS RED
dhali
Re: Wanted : B5 (2001) RS4 Front mounted oil cooler
Post by dhali » Tue May 01, 2018 7:44 am
Get a setrab one . It's the same thing . You just have to get someone to weld the the brackets from your original oil cooler onto the setrab one . Plus you can fit stainless steel fittings you will never have the corroded joints issue again .
weta.worker
Post by weta.worker » Tue May 01, 2018 9:35 am
Thanks! You wouldn't to happen to have a link to the correct part?
Cheers!
1994 RS2 GUARDS RED
dhali
Post by dhali » Tue May 01, 2018 9:53 am
https://www.rennsportshop.com/de-fahrze ... ction_ms=1
Double check dimensions on your Oem cooler . And you have to buy the fittings to fit your Oem pipes seperatley .
weta.worker
Post by weta.worker » Tue May 01, 2018 10:03 am
cheers!
1994 RS2 GUARDS RED
Users browsing this forum: No registered users and 23 guests
