Exhaust flaps
KernowPete
Exhaust flaps
Post by KernowPete » Wed Apr 04, 2018 5:08 pm
Hi all
The car has been sitting for a while and now the exhaust flaps are not opening in sport mode. Indeed they are closed when the engine is off meaning hopefully they are just stuck. I have no other symptoms of vacuum issues. But my question is, how freely do they move when not seized? Should you be able to move them fairly easy by hand (with a long tool obviously)? I've had a play and I can't move mine so much as a millimetre. Any advice greatly appreciated!!
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
Grandadg90
Re: Exhaust flaps
Post by Grandadg90 » Wed Apr 04, 2018 5:44 pm
Spray both flaps with wd40. Leave it 30 minutes. Then pry the flaps open with a bar/long screw driver. Keep opening and closing them manually. They should free up. You may have to try this a few times. Finally spray them with silicone lube.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
12th
Re: Exhaust flaps
Post by 12th » Thu Apr 05, 2018 8:01 am
I've used WD40 and found it stops them squeaking, so the above makes sense.
KernowPete
Re: Exhaust flaps
Post by KernowPete » Thu Apr 05, 2018 9:31 am
Thanks for replies so far. A few applications of WD40 has at least got them moving but still they need a lot of force to move (ie a long tool tapped with a rubber mallet). Another thread on here mentioned brake cleaner might possibly be a better solution - any thoughts?
Users browsing this forum: Majestic-12 [Bot] and 151 guests
