New clutch an parts for supercharger power
Lukes3
Post by Lukes3 » Sat Jan 13, 2018 1:11 pm
Can anyone recommend a clutch kit that will do for holding the power an having a little beating and not giving up,
I have been reading on here an it says a new oem clutch with all the other parts will do just fine for abit but i dont mind spending that little more for a better kit.
Also needs to drive nice aswell and cant have a lightweight flywheel due to the tts supercharger kit having a light weight front pully.
Cheers.
jonytek
Re: New clutch an parts for superchared power
Post by jonytek » Sat Jan 13, 2018 7:37 pm
I thought mrc recommend oem but tts something a bit stronger. I'd think Mrc's advice would be sound. This is assuming you're not going for the 900hp kit, that's a different ball game.
BUILD THREAD
IG: @bad_rs_4
Lukes3
Post by Lukes3 » Sat Jan 13, 2018 8:05 pm
Yes mrc say oem clutch but tts say another but im sure i have heard problems with the one tts recommend,
I have looked in to the upgrade unit but im waiting for the out come on that.
m2motortechnik
Post by m2motortechnik » Sat Jan 13, 2018 8:45 pm
the stock clutch will do just fine with the tts kit because its not making that much more torque then factory,when you start running 400 fptorque thats when you need to upgrade to a stronger clutch,the power of the tts kit is very linear ,but all depends how much you beat on the clutch,i would recommend to upgrade to a stage 2 clutch
DavidRS4
Post by DavidRS4 » Sat Jan 13, 2018 10:11 pm
Why can’t you run a lightweight flywheel with the lightweight pulley?
Lukes3
Post by Lukes3 » Sun Jan 14, 2018 12:05 pm
Because the front pulley “damper” as been replaced with a single billet aluminium pulley with no dampening, you can get away with this because the car comes with a Dualmass flywheel what takes it.
If you replacing the flywheel with a single mass light weight flywheel there is nothing taking the vibration/hits away directly to the crank
End result will be the crank been knocked out.
I think this makes sense :roll:
DavidRS4
Post by DavidRS4 » Sun Jan 14, 2018 12:39 pm
I run a JHM Stage 3 clutch with a lightweight flywheel. So I wouldn’t be able to supercharge mine unless I changed my flywheel back to a dual mass one?
Lukes3
Post by Lukes3 » Sun Jan 14, 2018 2:08 pm
Yes i think that is correct, unless someone else knows different?
That is why i dont know what clutch to go for, because most of the upgraded kit have lightweight flywheels
m2motortechnik
Post by m2motortechnik » Sun Jan 14, 2018 8:01 pm
you will be fine with a light weight flywheel
Lukes3
Post by Lukes3 » Sun Jan 14, 2018 8:48 pm
Duel-mass lightweight if one can be found? Or single-mass lightweight
Mat20vt
Post by Mat20vt » Sun Jan 14, 2018 9:16 pm
Intrested in this. Want to swap mine over soon before supercharging.
Rather get it right now than change twice
Previously big turbo'd mk4 golf, big turbo'd Audi A3 Quattro
Currently remapped vw caddy
& 2009 rs4 saloon, TTS supercharged, mrc mapped, miltek catback, kwv3, h&r arbs, gutted precats, ceramic brakes 610bhp 👍
JCviggen
Post by JCviggen » Mon Jan 15, 2018 10:34 am
It does make sense, but it's wrong. The dual mass flywheels don't prevent vibrations in the engine, they aim to prevent sending those vibrations down the driveline. Hence gearbox chatter etc with a single mass one. It's a comfort/refinement thing more than anything else.
I can't recall hearing of any supercharged cars on the other side of the pond developing engine issues due to lack of damping in the pulley or flywheel.
981 Cayman GTS Gray/Orange.
My youtube
DavidRS4
Post by DavidRS4 » Mon Jan 15, 2018 11:55 am
Thank your for clearing that up 👍
Lukes3
Post by Lukes3 » Mon Jan 15, 2018 12:45 pm
Thanks for that,
So if i get all the gear it should be fine.
Lukes3
How are you finding your clutch david?
Users browsing this forum: No registered users and 466 guests
