Hi
I have an RS4 B8 and been flashed a couple of times this week, I got the impression the highlights were too high but they weren't on full beam. Car has passed Mot this week but just had new drivers side headlight fitted due to problem with adaptive head light fault
is there a way to adjust the headlight beam down ?
RS4 B8 Headlights too high ?
- Surrey Sam
Re: RS4 B8 Headlights too high ?
Yes, the headlight should be manually adjusted to the correct target board. Then an adaptation programme should be run, so that the headlight range module learns the scope it has to the adjust for cornering lights and self-levelling.
Many thanks
I check with the garage that they did that
Clive
Clive
