Airbox flap
Airbox flap
Hi could someone shed some light on the airbox flap not working please.
Tomorrow I’m going to check and see if it’s seized. If so can the flap be removed without issue or does this cause an issue with the computer system.
Lewis
Lewis
Re: Airbox flap
I'm fairly certain it is not monitored so shouldn't cause any alarms. Having it open all the time will mean you are letting in hot air at lower revs when a high volume of air is not required. The flap should open at higher revs when the engine needs more air and in theory the car should be moving faster which will negate some of the hot air issues. Fitting a cold air feed straight into the flap inlet will restrict the amount of hot air getting in at lower revs. But to do this effectively you need to remove the drivers side auxiliary radiator (or drill a big hole in the wing like that car had in ebay).
Re: Airbox flap
That white cab advert was comicalMikeFish wrote: ↑Tue Jan 02, 2018 4:35 pmI'm fairly certain it is not monitored so shouldn't cause any alarms. Having it open all the time will mean you are letting in hot air at lower revs when a high volume of air is not required. The flap should open at higher revs when the engine needs more air and in theory the car should be moving faster which will negate some of the hot air issues. Fitting a cold air feed straight into the flap inlet will restrict the amount of hot air getting in at lower revs. But to do this effectively you need to remove the drivers side auxiliary radiator (or drill a big hole in the wing like that car had in ebay).
Re: Airbox flap
I had no issues removing mine when I fitnthe cold air feed. There's a thread at the top of this forum in the diy caf. Easy pezzy.
Re: Airbox flap
Mine has been out for months now... Been running fine! Initially removed it to fix it since flap was stuck and I was having hesitation issues.
I'll get it back in at some point, but just being lazy.
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
Re: Airbox flap
Cheers lads
Well I tried to clean up and re-grease the flap as it was a little stiff but didn’t notice much difference. I may remove it and see if there is once removed.
RS4eddie you said you removed it. I take it you can remove without damaging it and fit back again does the whole airbox have to come out for that.
Re: Airbox flap
holsy10 wrote:Cheers lads
2007 RS4 B7 Avant
Re: Airbox flap
when i say clean up just clean the bits of dust that was in the airbox and sprays the flap with wd40 Sent from my iPhone using Tapatalk
Re: Airbox flap
You know everyone loves a greasy flap
Re: Airbox flap
My tech removed it -- think the whole airbox was removed to get to that housing with flap.holsy10 wrote:Cheers lads
Once out make sure you plug the vacuum line.
It's much easier to clean up/sand when removed. Good luck!!
Re: Airbox flap
Might be a stupid question, bit do I have to remove whole airfilter box to get to this flap ?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 275 guests
