RS4 brake disc life
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
SandyT
RS4 brake disc life
Post by SandyT » Thu Dec 07, 2017 4:44 pm
How long would B8 RS4 owners expect OEM discs (and pads) to last?
Just had mine in for a service (at a reputable indy) and been told that the fronts need replaced after 16k. The specialists were appalled. Admittedly the first 4K wasn't in my ownership but it wasn't raised at last year's service (at about 8k).
I don't track and I'm not overly hard on the brakes. The IS-F I had previously was about 35k before needing new discs, which I think is reasonable.
Surrey Sam
Re: RS4 brake disc life
Post by Surrey Sam » Thu Dec 07, 2017 5:52 pm
Might be better off asking this in the B8 RS4 section, for more comments. I'd be surprised at it needing new discs though, unless it's seen track work.
At my request, I had front pads replaced at 17k miles as they wouldn't have lasted until the next service. There was still around 3mm of material left and I would say that I'm a moderate to hard road user with braking. Steel discs should roughly be replaced after the 2nd pad set wears out.
SandyT
Post by SandyT » Fri Dec 08, 2017 10:48 am
More details having spoken with the mechanic - it's severe corrosion at the rear of the front discs as opposed to excessive wear.
Interestingly the rears are absolutely fine!
SandyT
Post by SandyT » Fri Dec 08, 2017 12:11 pm
That's what I would have expected as well - however with the corrosion, if the discs have to be changed, the pads will have to be too :-(
With the rears being fine, I'll raise it as a quality issue with Audi and see where that gets me.
Surrey Sam
Post by Surrey Sam » Fri Dec 08, 2017 12:41 pm
Sounds odd if I'm honest, how reputable is this independent? Can they send you a picture?
If there's excessive corrosion to the inside disc face, then the pad is not making proper contact and would instead point to a faulty/corroded calliper. Sure you'll need to replace discs and pads but just doing that, is not solving the problem. Hence the scenario sounding rather odd.
noddy
Post by noddy » Tue Dec 12, 2017 5:45 pm
Get them skimmed if corroded? check calliper pistons also, they should push back by hand.
SandyT
Post by SandyT » Wed Dec 13, 2017 11:58 am
I had thought about getting them skimmed, yes - I did have that done on a set when i had a 350Z.
Surrey Sam, it's a good point about the pads not making correct contact.
DeanoC
Post by DeanoC » Wed Jan 03, 2018 1:27 pm
My original set lasted about 22k. Second set were nearly done at 38k (80% worn)
Sent from my Pixel 2 using Tapatalk
Return to “Audi S and RS Ownership”
Users browsing this forum: Majestic-12 [Bot] and 9 guests
