VAG com diagnostic tool
Skutcho
Post by Skutcho » Fri Dec 01, 2017 12:40 pm
Hello all, I'm looking to get a Vag Com VCDS reader tool to try and reset the TPMS alert on my rs4 b7. Anyone use these or recommend one. I notice loads on the web in varying prices. I want something that's going to work and be useful. Any advice appreciated.
iconic78
Re: VAG com diagnostic tool
Post by iconic78 » Sat Dec 02, 2017 9:10 am
Rosstech are the company that makes the cable and software. All the others are copies.
With the cable you can a lot more than just reset your tpms.
rs user
Post by rs user » Sun Dec 03, 2017 8:36 pm
the copies are fine if you dont let them update-as long as you get the hexcan model-when ross tech started limiting vins like the range rover tools etc i was happy to use the copied software-i also use a snap on solus pro-but its not as good as Vag Com tbh
Post by chunky79 » Sun Dec 03, 2017 8:46 pm
You could always ask if someone local has one and can scan the car for you.
Return to “DTC / VCDS”
