Tyre pressure
DXB_RS6
Tyre pressure
Post by DXB_RS6 » Wed Oct 04, 2017 6:40 am
Can someone tell me what the tyre pressure should be?
13
C7Image
Sent from my SM-G955F using Tapatalk
doodlebug
Tyre pressure
Post by doodlebug » Wed Oct 04, 2017 6:46 am
Should be a Sticker on the driver’s door pillar. Failing that they are in the manual.
rtd
Re: Tyre pressure
Post by rtd » Wed Oct 04, 2017 7:31 am
here you go
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
superlightr
Re: Tyre pressure
Post by superlightr » Wed Oct 04, 2017 7:53 am
im running 42 on each
Re: Tyre pressure
Post by MikeFish » Wed Oct 04, 2017 8:32 am
My door Sticker has higher values. I run mine at 36 and 39 (door says 38 and 41).
Markp
Re: Tyre pressure
Post by Markp » Wed Oct 04, 2017 9:40 am
Mine is the same as rtd above. But when cold remember not at the temperatures you are showing.
DXB_RS6
Re: Tyre pressure
Post by DXB_RS6 » Thu Oct 05, 2017 7:47 pm
Thanks all. I have added the right air in the tyre but the fault light is still showing.
How do I reset/clear the fault light?
rtd
Re: Tyre pressure
Post by rtd » Thu Oct 05, 2017 7:48 pm
In the menu where it says display tyre pressures I think under that option u can scroll down to reset new pressures that will store the new figures and hopefully remove the error
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Tadass910
Re: Tyre pressure
Post by Tadass910 » Sat Oct 07, 2017 11:12 am
I run 3.00 bar front and 2.8 rears, plus pressure goes higher after you drive long time or hot day, because of hot air in a tires
DXB_RS6
Re: Tyre pressure
Post by DXB_RS6 » Sat Oct 07, 2017 7:36 pm
Got it. Thanks all.
Temperature looks high while on the track today ImageImage
