Downpipes audi rs6 2003
What is envolved when replacing exhaust downpipes with decat or sports cat.
Sent from my D6603 using Tapatalk
Re: Downpipes audi rs6 2003
You'll need to lower the back half of the engine on its subframe to get access too the bolts on the exhausts you'll also need too pull the wiring through from the top for the two upper lambdas.
But be careful you don't lower it too much and damage any wiring , pipework or mounts.
I would guess you'd want the prop out the way too so you'll loose some oil which needs replacing .
Cheers Al
04 c5 rs6 , Ebony Black, Bare shell repaint , Milltek's, PSS9's,Hotchkis Arb's,Gutted precats, hybrid turbos, Bosch 044 ,And an annoying EML light
You don't lose any oil by dropping the prop shaft.
Oh s**t , yeah it's on a flange isn't it . So ignore that bit .
Cheers Al
Great. Thanks guys.
Greenslade
- 1st Gear
Which pipes are you going for?
2003 RS6 Avant in Ebony Black/Silver Nappa - Wagners, Millteks, MRC Stage 2 map, Bosch 044, Sports Cats, Bilsteins, Hotchkis ARBs, 390mm C6 discs, Recaro CS, RNS-E, LED tail-lights, Goodyear Eagle F1s,......Porsche filler caps
Miltek or custom decatGreenslade wrote:Which pipes are you going for?
Greenslade
- 1st Gear
My car WAS decatted for a few years, but the previous owner had some 200 cell sports cats made up by Powervalve in Merseyside, about a year ago.
Users browsing this forum: No registered users and 157 guests
